Hi. I’m wondering which installation method is the “recommended method” when it comes to later updates? I’ve installed a RC on Debian by following this guide, but it seems like updating is quite complex.
Then I stumbled upon this Snap article, which seems much easier. Would you recommend to start over, this time with a Snap installation?
I personally prefer docker
It just seems a bit complex to me, having to deal with both Docker and the RC installation
. I have no problem in spinning up a VM just for RC, but e.g. the update process for manual installation, seems very complex and risky in terms of database upgrades etc.
it’s really not complicated.
Also, upgrading a docker deploy is really just changing versions and issuing a couple of commands.
I do not recommend manual installation (from source .tar.bz).
We are writing a blog post regarding deployment method and should post it soon.
Next, I will be looking for a blog post that discusses several methods of deployment.
