Hello, I want to limit the permissions of one user - I want him to be able to read posts, but not to write (privilege for a specific channel, not globally).
What is the simplest solution for this type of task?
Is it possible to add an option - block user messages in a channel?
Thanks for the help in advance
Hi @WebDevAnki, welcome to our Community
You can mute a user on a per channel basis, considering your are owner or moderator of that channel.
I believe this will accomplish what you are looking for.
Let me know if this helps!
Hello! Thanks for your reply. My problems stem from an outdated RC version. It’s great that the current version has an option to mute a user in a channel.
Regards
