I can’t create the initial User. It stucks.
If I reload the page then it will show the normal login prompt, but I can only login with email and password, because the username is not created. Rocketchat askes for it afterward. Then the setup continues.
If a new user register itself, its the same. New user with email and password, but no username.
What can I do? It’s a complete fresh installation.
LocalStore: store created at ,
Setting default file store to GridFS,
ufs: temp directory created at "/tmp/ufs",
Updating process.env.MAIL_URL,
Starting Email Intercepter...,
Loaded the Apps Framework and loaded a total of 0 Apps!,
Using GridFS for custom sounds storage,
Using GridFS for custom emoji storage,
➔ System ➔ startup,
➔ | SERVER RUNNING |,
➔ | Rocket.Chat Version: 3.18.0 |,
➔ | NodeJS Version: 12.22.1 - x64 |,
➔ | MongoDB Version: 4.0.26 |,
➔ | MongoDB Engine: mmapv1 |,
➔ | Platform: linux |,
➔ | Process Port: 3000 |,
➔ | Site URL: https://chat.demo.domain |,
➔ | ReplicaSet OpLog: Enabled |,
➔ | Commit Hash: a57b10e779 |,
➔ | Commit Branch: HEAD |,
(node:8) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
It sits behind a reverse proxy.
COMPOSE:
rocketchat:
image: rocket.chat
command: >
bash -c
"for i in `seq 1 30`; do
node main.js &&
s=$$? && break || s=$$?;
sleep 5;
done; (exit $$s)"
restart: unless-stopped
volumes:
- /home/kartoffel/_files/rocketchat/uploads:/app/uploads
- PORT=3000
- ROOT_URL=https://chat.demo.domain
- MONGO_URL=mongodb://mongo-rocket:27017/rocketchat
- MONGO_OPLOG_URL=mongodb://mongo-rocket:27017/local
- MAIL_URL=smtp://smtp.email
depends_on:
- mongo-rocket
ports:
- 3000:3000
labels:
traefik.enable: "true"
traefik.docker.network: "weave"
traefik.http.routers.bdchat.entrypoints: "https"
traefik.http.routers.bdchat.rule: "Host(`chat.demo.domain`)"
traefik.http.routers.bdchat.tls: "true"
traefik.http.routers.bdchat.priority: "100"
traefik.http.services.bdchat.loadbalancer.server.port: "3000"
mongo-rocket:
image: mongo:4.0
volumes:
- /home/kartoffel/_files/rocketchat/db:/data/db
#- ./data/dump:/dump
hostname: 'mongo-rocket'
mongo-rocket-init-replica:
image: mongo:4.0
command: >
bash -c
mongo mongo-rocket/rocketchat --eval \"
rs.initiate({
_id: 'rs0',
sleep 5;
done; (exit $$s)"
depends_on:
- mongo-rocket
Mongo Log:
2021-09-07T15:37:21.713+0000 I INDEX [conn12] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.714+0000 I INDEX [conn7] build index on: rocketchat.rocketchat_livechat_priority properties: { v: 2, unique: true, key: { dueTimeInMinutes: 1 }, name: "dueTimeInMinutes_1", ns: "rocketchat.rocketchat_livechat_priority" },
2021-09-07T15:37:21.714+0000 I INDEX [conn7] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.714+0000 I INDEX [conn7] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.715+0000 I SHARDING [conn3] Marking collection rocketchat.rocketchat_livechat_tag as collection version: <unsharded>,
2021-09-07T15:37:21.716+0000 I STORAGE [conn14] createCollection: rocketchat.rocketchat_livechat_tag with generated UUID: 74202861-6d54-4573-a620-a82a53e495e1,
2021-09-07T15:37:21.716+0000 I INDEX [conn14] build index on: rocketchat.rocketchat_livechat_tag properties: { v: 2, key: { _updatedAt: 1 }, name: "_updatedAt_1", ns: "rocketchat.rocketchat_livechat_tag" },
2021-09-07T15:37:21.716+0000 I INDEX [conn14] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.716+0000 I INDEX [conn14] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.717+0000 I INDEX [conn4] build index on: rocketchat.rocketchat_livechat_tag properties: { v: 2, unique: true, key: { name: 1 }, name: "name_1", ns: "rocketchat.rocketchat_livechat_tag" },
2021-09-07T15:37:21.717+0000 I INDEX [conn4] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.717+0000 I INDEX [conn4] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.719+0000 I SHARDING [conn5] Marking collection rocketchat.rocketchat_livechat_unit_monitors as collection version: <unsharded>,
2021-09-07T15:37:21.720+0000 I STORAGE [conn10] createCollection: rocketchat.rocketchat_livechat_unit_monitors with generated UUID: 4be10626-3921-49e4-b2b7-1801eedda68f,
2021-09-07T15:37:21.720+0000 I INDEX [conn10] build index on: rocketchat.rocketchat_livechat_unit_monitors properties: { v: 2, key: { _updatedAt: 1 }, name: "_updatedAt_1", ns: "rocketchat.rocketchat_livechat_unit_monitors" },
2021-09-07T15:37:21.720+0000 I INDEX [conn10] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.720+0000 I INDEX [conn10] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.721+0000 I INDEX [conn12] build index on: rocketchat.rocketchat_livechat_unit_monitors properties: { v: 2, key: { monitorId: 1 }, name: "monitorId_1", ns: "rocketchat.rocketchat_livechat_unit_monitors" },
2021-09-07T15:37:21.721+0000 I INDEX [conn12] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.721+0000 I INDEX [conn12] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.722+0000 I INDEX [conn7] build index on: rocketchat.rocketchat_livechat_unit_monitors properties: { v: 2, key: { unitId: 1 }, name: "unitId_1", ns: "rocketchat.rocketchat_livechat_unit_monitors" },
2021-09-07T15:37:21.722+0000 I INDEX [conn7] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.722+0000 I INDEX [conn7] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.754+0000 I STORAGE [conn11] createCollection: rocketchat.omnichannel_queue_inactivity_monitor with generated UUID: c375ebed-6712-4034-8a16-2f847fbcbb65,
2021-09-07T15:37:21.755+0000 I INDEX [conn11] build index on: rocketchat.omnichannel_queue_inactivity_monitor properties: { v: 2, key: { name: 1, nextRunAt: 1, priority: -1, lockedAt: 1, disabled: 1 }, name: "findAndLockNextJobIndex", ns: "rocketchat.omnichannel_queue_inactivity_monitor" },
2021-09-07T15:37:21.755+0000 I INDEX [conn11] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.755+0000 I INDEX [conn11] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.880+0000 I SHARDING [conn3] Marking collection rocketchat.migrations as collection version: <unsharded>,
2021-09-07T15:37:21.882+0000 I STORAGE [conn14] createCollection: rocketchat.migrations with generated UUID: 096c236d-6d51-4bbc-85d6-df9ea9c66540,
2021-09-07T15:37:21.959+0000 I SHARDING [conn11] Marking collection rocketchat.rocketchat_cron_history as collection version: <unsharded>,
2021-09-07T15:37:21.960+0000 I STORAGE [conn13] createCollection: rocketchat.rocketchat_cron_history with generated UUID: 9aca3df3-e9dd-4836-aef7-a6b3d491fb6c,
2021-09-07T15:37:21.961+0000 I INDEX [conn13] build index on: rocketchat.rocketchat_cron_history properties: { v: 2, unique: true, key: { intendedAt: 1, name: 1 }, name: "intendedAt_1_name_1", ns: "rocketchat.rocketchat_cron_history" },
2021-09-07T15:37:21.961+0000 I INDEX [conn13] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.961+0000 I INDEX [conn13] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:21.963+0000 I INDEX [conn6] build index on: rocketchat.rocketchat_cron_history properties: { v: 2, key: { startedAt: 1 }, name: "startedAt_1", ns: "rocketchat.rocketchat_cron_history", expireAfterSeconds: 172800 },
2021-09-07T15:37:21.963+0000 I INDEX [conn6] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:21.963+0000 I INDEX [conn6] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.899+0000 I SHARDING [conn10] Marking collection rocketchat.rocketchat_apps as collection version: <unsharded>,
2021-09-07T15:37:23.901+0000 I STORAGE [conn11] createCollection: rocketchat.rocketchat_apps with generated UUID: 1fe5897e-dd21-45e9-be66-2c0c7e669999,
2021-09-07T15:37:23.902+0000 I INDEX [conn11] build index on: rocketchat.rocketchat_apps properties: { v: 2, key: { _updatedAt: 1 }, name: "_updatedAt_1", ns: "rocketchat.rocketchat_apps" },
2021-09-07T15:37:23.902+0000 I INDEX [conn11] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.902+0000 I INDEX [conn11] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.904+0000 I SHARDING [conn12] Marking collection rocketchat.rocketchat_apps_logs as collection version: <unsharded>,
2021-09-07T15:37:23.905+0000 I STORAGE [conn7] createCollection: rocketchat.rocketchat_apps_logs with generated UUID: 0264e0d1-8750-425e-b0e4-9cfa52fcf873,
2021-09-07T15:37:23.906+0000 I INDEX [conn7] build index on: rocketchat.rocketchat_apps_logs properties: { v: 2, key: { _updatedAt: 1 }, name: "_updatedAt_1", ns: "rocketchat.rocketchat_apps_logs", expireAfterSeconds: 2592000 },
2021-09-07T15:37:23.906+0000 I INDEX [conn7] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.906+0000 I INDEX [conn7] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.907+0000 I INDEX [conn3] build index on: rocketchat.rocketchat_apps_logs properties: { v: 2, key: { appId: 1 }, name: "appId_1", ns: "rocketchat.rocketchat_apps_logs" },
2021-09-07T15:37:23.907+0000 I INDEX [conn3] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.907+0000 I INDEX [conn3] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.908+0000 I SHARDING [conn6] Marking collection rocketchat.rocketchat_apps_persistence as collection version: <unsharded>,
2021-09-07T15:37:23.908+0000 I STORAGE [conn14] createCollection: rocketchat.rocketchat_apps_persistence with generated UUID: 5f9ce16d-e302-4dbf-a178-72dd0e2d7ad1,
2021-09-07T15:37:23.909+0000 I INDEX [conn14] build index on: rocketchat.rocketchat_apps_persistence properties: { v: 2, key: { _updatedAt: 1 }, name: "_updatedAt_1", ns: "rocketchat.rocketchat_apps_persistence" },
2021-09-07T15:37:23.909+0000 I INDEX [conn14] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.909+0000 I INDEX [conn14] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.909+0000 I INDEX [conn10] build index on: rocketchat.rocketchat_apps_persistence properties: { v: 2, key: { appId: 1 }, name: "appId_1", ns: "rocketchat.rocketchat_apps_persistence" },
2021-09-07T15:37:23.909+0000 I INDEX [conn10] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.909+0000 I INDEX [conn10] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.918+0000 I STORAGE [conn4] createCollection: rocketchat.rocketchat_apps_scheduler with generated UUID: a02ed6f8-5e03-4ae5-811b-99f439ff959d,
2021-09-07T15:37:23.919+0000 I INDEX [conn4] build index on: rocketchat.rocketchat_apps_scheduler properties: { v: 2, key: { name: 1, nextRunAt: 1, priority: -1, lockedAt: 1, disabled: 1 }, name: "findAndLockNextJobIndex", ns: "rocketchat.rocketchat_apps_scheduler" },
2021-09-07T15:37:23.919+0000 I INDEX [conn4] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:23.919+0000 I INDEX [conn4] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:23.923+0000 I COMMAND [conn13] CMD: drop rocketchat.rocketchat_raw_imports,
2021-09-07T15:37:23.923+0000 I STORAGE [conn13] dropCollection: rocketchat.rocketchat_raw_imports (ec30f8df-0e71-458c-a505-147689b1ede7) - renaming to drop-pending collection: rocketchat.system.drop.1631029043i365t1.rocketchat_raw_imports with drop optime { ts: Timestamp(1631029043, 365), t: 1 },
2021-09-07T15:37:23.923+0000 I STORAGE [conn13] renameCollection: renaming collection ec30f8df-0e71-458c-a505-147689b1ede7 from rocketchat.rocketchat_raw_imports to rocketchat.system.drop.1631029043i365t1.rocketchat_raw_imports,
2021-09-07T15:37:23.937+0000 I REPL [replication-0] Completing collection drop for rocketchat.system.drop.1631029043i365t1.rocketchat_raw_imports with drop optime { ts: Timestamp(1631029043, 365), t: 1 } (notification optime: { ts: Timestamp(1631029043, 368), t: 1 }),
2021-09-07T15:37:23.937+0000 I STORAGE [replication-0] Finishing collection drop for rocketchat.system.drop.1631029043i365t1.rocketchat_raw_imports (ec30f8df-0e71-458c-a505-147689b1ede7).,
2021-09-07T15:37:24.586+0000 I INDEX [conn13] build index on: rocketchat.rocketchat_message properties: { v: 2, key: { pinnedBy._id: 1 }, name: "pinnedBy._id_1", ns: "rocketchat.rocketchat_message", sparse: 1 },
2021-09-07T15:37:24.586+0000 I INDEX [conn13] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:24.586+0000 I INDEX [conn13] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:24.596+0000 I INDEX [conn6] build index on: rocketchat.rocketchat_message properties: { v: 2, key: { starred._id: 1 }, name: "starred._id_1", ns: "rocketchat.rocketchat_message", sparse: 1 },
2021-09-07T15:37:24.596+0000 I INDEX [conn6] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:24.596+0000 I INDEX [conn6] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:25.502+0000 I STORAGE [conn6] createCollection: rocketchat.omnichannel_auto_close_on_hold_scheduler with generated UUID: d1d58e27-8c15-4254-a01f-e2adfc51e47c,
2021-09-07T15:37:25.502+0000 I INDEX [conn6] build index on: rocketchat.omnichannel_auto_close_on_hold_scheduler properties: { v: 2, key: { name: 1, nextRunAt: 1, priority: -1, lockedAt: 1, disabled: 1 }, name: "findAndLockNextJobIndex", ns: "rocketchat.omnichannel_auto_close_on_hold_scheduler" },
2021-09-07T15:37:25.502+0000 I INDEX [conn6] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:25.502+0000 I INDEX [conn6] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:25.503+0000 I STORAGE [conn7] createCollection: rocketchat.omnichannel_scheduler with generated UUID: 0d4cb4eb-4f66-40f1-ab44-a5b54b48fc93,
2021-09-07T15:37:25.504+0000 I STORAGE [FileAllocator] allocating new datafile /data/db/rocketchat.2,
2021-09-07T15:37:25.505+0000 I STORAGE [FileAllocator] done allocating datafile /data/db/rocketchat.2, size: 64MB, took 0 secs,
2021-09-07T15:37:25.505+0000 I INDEX [conn7] build index on: rocketchat.omnichannel_scheduler properties: { v: 2, key: { name: 1, nextRunAt: 1, priority: -1, lockedAt: 1, disabled: 1 }, name: "findAndLockNextJobIndex", ns: "rocketchat.omnichannel_scheduler" },
2021-09-07T15:37:25.505+0000 I INDEX [conn7] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:25.505+0000 I INDEX [conn7] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:25.564+0000 I SHARDING [conn10] Marking collection rocketchat.ufsTokens as collection version: <unsharded>,
2021-09-07T15:37:25.565+0000 I STORAGE [conn5] createCollection: rocketchat.ufsTokens with generated UUID: 3af329e1-7fc1-445d-93cc-630475e838d2,
2021-09-07T15:37:25.646+0000 I SHARDING [conn11] Marking collection rocketchat.rocketchat_avatars.files as collection version: <unsharded>,
2021-09-07T15:37:25.649+0000 I STORAGE [conn3] createCollection: rocketchat.rocketchat_avatars.files with generated UUID: a0246fc0-8164-4e6d-86dd-85cd09f082e2,
2021-09-07T15:37:25.650+0000 I INDEX [conn3] build index on: rocketchat.rocketchat_avatars.files properties: { v: 2, key: { filename: 1, uploadDate: 1 }, name: "filename_1_uploadDate_1", ns: "rocketchat.rocketchat_avatars.files", background: false },
2021-09-07T15:37:25.650+0000 I INDEX [conn3] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:25.650+0000 I INDEX [conn3] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:37:25.651+0000 I SHARDING [conn4] Marking collection rocketchat.rocketchat_avatars.chunks as collection version: <unsharded>,
2021-09-07T15:37:25.651+0000 I STORAGE [conn10] createCollection: rocketchat.rocketchat_avatars.chunks with generated UUID: 97761d1a-2538-48cc-904e-7751241b2601,
2021-09-07T15:37:25.652+0000 I INDEX [conn10] build index on: rocketchat.rocketchat_avatars.chunks properties: { v: 2, unique: true, key: { files_id: 1, n: 1 }, name: "files_id_1_n_1", ns: "rocketchat.rocketchat_avatars.chunks", background: false },
2021-09-07T15:37:25.652+0000 I INDEX [conn10] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:37:25.652+0000 I INDEX [conn10] build index done. scanned 0 total records. 0 secs,
2021-09-07T15:42:10.072+0000 I CONTROL [LogicalSessionCacheReap] Sessions collection is not set up; waiting until next sessions reap interval: config.system.sessions does not exist,
2021-09-07T15:42:10.072+0000 I STORAGE [LogicalSessionCacheRefresh] createCollection: config.system.sessions with generated UUID: d159d3f4-d052-43d9-a454-9580998eb880,
2021-09-07T15:42:10.072+0000 I INDEX [LogicalSessionCacheRefresh] build index on: config.system.sessions properties: { v: 2, key: { lastUse: 1 }, name: "lsidTTLIndex", ns: "config.system.sessions", expireAfterSeconds: 1800 },
2021-09-07T15:42:10.072+0000 I INDEX [LogicalSessionCacheRefresh] building index using bulk method; build may temporarily use up to 500 megabytes of RAM,
2021-09-07T15:42:10.072+0000 I INDEX [LogicalSessionCacheRefresh] build index done. scanned 0 total records. 0 secs
