Hi
I installed rocketchat sever with snap and i want to run it on multi instances, but the tutorial under this link refer to installation manually, what is diff and how can i multi instance my rocketcaht ?
thanks.
Hi
thanks.
With snaps you currently cannot do multi-instance. Basically snaps are good for getting your feet wet. But if you want to scale you’ll need to migrate to another option.
This is so bad !!
please add this to document .
Please feel free to open a PR adding this as a note on the snaps FAQ.
