I’m having some troubles restoring my rocketchat database from a standalone (Ubuntu) instance over to a Docker instance.
The mongorestore works fine and it builds all the indexes, etc, but when I go to login it’s not using the data I restored but rather a “new default instance”.
I’m new to Docker so I have a feeling it’s related to something with the container.
Thanks to anyone who looks or can help. I’m a big fan of this most excellent software.
Make sure to use the right connection string. Something like: mongodb://server:27017/{name of database restored}
Thank you so much @aaron.ogle, that worked perfectly. I’m kind of embarrassed honestly but very happy to have it working now thanks to your help.
The example I was following used “db” for the name of the database and I “assumed” that the mongorestore command would magically make it all work
Unfortunately it doesn’t. Glad you got it working!
