Mongorestore doesn't restore messages
Using:
docker exec -i container_id sh -c 'mongorestore --archive' > ~/rocket.backups/db.dump
Does not restore conversations between users. It does restore users and any settings I had. The last entry of the mongorestore states a certain number of files failed to restore, but I haven’t figured out how to redirect the output of the above command so that I can check for errors. Any suggestions would be helpful.
  • Version of Rocket.Chat Server: 7.1.0
  • Operating System: RHEL 8
  • Deployment Method: docker
  • DB Replicaset Oplog: Not sure what this is
  • NodeJS Version: N/A
  • MongoDB Version: 6.0.13
  • Proxy: apache
  • Firewalls involved: N/A
This is a very early deployment of Rocket.Chat. The “conversations” are brief messages sent between Admin created users. So I’m also not sure if this is because of how little data is actually being restored, however I wanted some level of confirmation so I can present to leadership whether the backup method is effective. Overall this is my first time working with Mongodb and Rocket.Chat
It’s a mongo issue more than Rocket.
Think your problem, if it exists, is the dump.
On my non docker mongo I use
mongodump -d rocketchat -o /root/backup
That creates a directory with the dump files.
You then restore from that directory.
So how did you create yours?
Note you should get a pile of bson files.
You can view them doing something like:
bsondump users.bson |jq
