Hello again!
I just recently got my RocketChat server set up, but after it was running for about 24hrs, ti started using many more resources than I felt comfortable with it using on a shared instance, so I’m moving it!
I found this link: Transfer to Snap install from Manual but, it describes a method to transfer from a manual installation to a snap installation. I tried to run the mongo export/dump command and was told that:
“The program ‘mongodump’ is currently not installed. You can install it by typing:
apt install mongodb-clients”
I currently have 0.62.2 installed but not running, and am looking to dump/backup and install/import everything on to the new installation on a different server instance. I used nginx, and plan to again, unless there is a convincing argument for using Caddy, and can provide any further info you might need for any assistance!
-Omni
Edit: I am seeing in the FAQ here: FAQ that I might be able to just do a database backup restore? Is it that simple to migrate everything?
Edit 2: It looks like the backup instructions were enough that I don’t have to set everything back up from scratch. Thanks for the help anyway!
