Migrate from mattermost API and DB help
Hello everyone! I’m trying to migrate from Mattermost to RocketChat. Both are self-hosted in Docker containers.
I’m extracting Mattermost data directly from a PostgreSQL database and sending it to RocketChat via the API.
I’ve successfully migrated users, channels, and private channels, but I’m stuck on messages.
When I transfer messages via the API, there’s no way to set the timestamp. As a result, the messages appear in the chat as if they were sent just now, whereas I need them to display with the correct date.
If I try inserting data directly into MongoDB, the messages don’t appear in the chat.
So I have two questions:
1 Is it possible to send a message in such a way that it appears with a past date?
2 How can I make Rocket.Chat display messages that were inserted directly into MongoDB?
Hi.
Can you tell a bit about your Rocket setup please?
Like this:
Any specific reasons why you are moving? Just curious as to what your needs are!
Yes messages will be tricky. I think it needs a direct injection to the DB.
I’ll try & see if anyone backstage has experience.
Why i want to migrate:
MM Mobile app getting worse for several years, slow UI, messaging, etc. My team mostly mobile app users, so we want to move to something different.
Seems like I figured it out.
No, api does not have such fields.
Before put data into mongo database message object must include _id field. After reading code i notice that id is random generated string not object, if message missing this - mongo generate _id as an object. So i just implement code like RC uses in internal libs in my importer and it works.
Cool. Nice to know and welcome!
Yes I did say that…
And…
Excellent.
Be good if you can post some code for others (open source is about sharing!)
