Is there a reason you’re setting it to false? I think it needs to be USE_NATIVE_OPLOG=true. Setting it to false probably won’t do anything since that’s the default value
Yes I think you have to use true since quite a ling while back. Not sure it will even allow false.
How would one set these environment variables when using a Snap ?
You can’t as far as I am aware.
Hello guys, I’m having the same issue here…
The default users can only send messages inside some channel or group, but direct/private messages are not being sent. The app was build with Snap in a Digital Ocean droplet on Ubuntu 18.04.
I applied the steps present here Snaps - Rocket.Chat Docs (I nano a config.env file and pasted USE_NATIVE_OPLOG = true inside it).
But, nothing works, somebody can help please?
