Hey Guys,
yesterday I set up an instance of Rocket.Chat via Docker-Compose. I tried so many things, that it would run through. After a few hours, I got it through the whole Installation and up and running.
But: Now I have the following problem:
I could create an admin-user at first setup and login to this account.
Now, when I open up the website, it just shows three dots animating and then there is no Login-Field. It’s just a blank grey page on url/home. I tried this on Opera, MS Edge, Firefox, Chrome, Safari. Same Problem everywhere… No Login-Form. I tried it on the IP:Port as well with subdomain.domain.de - no chance. It seems there is a problem with “too many requests”…
Why is this? How can I make it work, that the Login-Form comes up everytime I enter the page?
Please help
Thank you!
- Version of Rocket.Chat Server: 4.1.2
- Operating System: Debian 11 Bullseye
- Deployment Method: docker-compose
- NodeJS Version: 12.22.1
- MongoDB Version: 4.2.17
- Proxy: Nginx Proxy Manager
- Firewalls involved: ???
My Setup is:
- Debian 11 Bullseye
- Docker
- Docker-Compose
- Portainer
- Nginx Proxy Manager
Here is my docker-compose.yml, where I had to change some stuff, while not using traefik (Nginx Proxy Manager) and troubleshooting deprecated mongoDB-versions. I also changed to port 2000, as I have some tools running, and 3000 is already in use:
version: '2'
services:
rocketchat:
image: registry.rocket.chat/rocketchat/rocket.chat:latest
command: >
bash -c
"for i in `seq 1 30`; do
node main.js &&
s=$$? && break || s=$$?;
sleep 5;
done; (exit $$s)"
restart: unless-stopped
volumes:
- ./uploads:/app/uploads
- PORT=2000
- ROOT_URL=http://subdomain.domain.de:2000
- MONGO_URL=mongodb://rocketchat_mongo_1:27017/rocketchat
- MONGO_OPLOG_URL=mongodb://rocketchat_mongo_1:27017/local
# - MAIL_URL=smtp://smtp.email
# - HTTP_PROXY=http://proxy.domain.com
# - HTTPS_PROXY=http://proxy.domain.com
depends_on:
- mongo
ports:
- 2000:2000
labels:
mongo:
image: mongo:4.2
volumes:
- ./data/db:/data/db
- ./data/dump:/dump
command: mongod --oplogSize 128 --replSet rs0 --storageEngine=wiredTiger
labels:
- "traefik.enable=false"
mongo-init-replica:
image: mongo:4.2
command: >
bash -c
rs.initiate({
_id: 'rs0',
sleep 5;
done; (exit $$s)"
depends_on:
- mongo
# hubot:
# image: rocketchat/hubot-rocketchat:latest
# restart: unless-stopped
# environment:
# - ROCKETCHAT_URL=rocketchat:2000
# - ROCKETCHAT_ROOM=GENERAL
# - ROCKETCHAT_USER=bot
# - ROCKETCHAT_PASSWORD=botpassword
# - BOT_NAME=bot
# - EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics
# depends_on:
# - rocketchat
# labels:
# - "traefik.enable=false"
# volumes:
# - ./scripts:/home/hubot/scripts
# this is used to expose the hubot port for notifications on the host on port 3001, e.g. for hubot-jenkins-notifier
# ports:
# - 2001:8080
#traefik:
# image: traefik:latest
# command: >
# traefik
# --docker
# --acme=true
# --acme.domains='your.domain.tld'
# --acme.email='your@email.tld'
# --acme.entrypoint=https
# --acme.storagefile=acme.json
# --defaultentrypoints=http
# --defaultentrypoints=https
# --entryPoints='Name:http Address::80 Redirect.EntryPoint:https'
# --entryPoints='Name:https Address::443 TLS.Certificates:'
# ports:
# - 80:80
# - 443:443
# volumes:
# - /var/run/docker.sock:/var/run/docker.sock
Inside Portainer I just had a look into the up and running container-logs:
Here is the Log for the rocketchat-container:
LocalStore: store created at
{"level":51,"time":"2021-11-10T17:40:12.132Z","pid":9,"hostname":"a2a91d0441b8","name":"Migrations","msg":"Not migrating, already at version 243"}
ufs: temp directory created at "/tmp/ufs"
| SERVER RUNNING |
| Rocket.Chat Version: 4.1.2 |
| NodeJS Version: 12.22.1 - x64 |
| MongoDB Version: 4.2.17 |
| Platform: linux |
| Process Port: 2000 |
| Site URL: http://IP:2000 |
| ReplicaSet OpLog: Enabled |
| Commit Hash: 2aba8d2d82 |
| Commit Branch: HEAD |
(node:9) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
:50,"time":"2021-11-10T17:54:07.318Z","pid":9,"hostname":"a2a91d0441b8","name":"System","msg":"Exception while invoking method userSetUtcOffset 'Error, too many requests. Please slow down. You must wait 39 seconds before trying again. [too-many-requests]'"}
:50,"time":"2021-11-10T17:54:17.410Z","pid":9,"hostname":"a2a91d0441b8","name":"System","msg":"Exception while invoking method userSetUtcOffset 'Error, too many requests. Please slow down. You must wait 60 seconds before trying again. [too-many-requests]'"}
{"level":50,"time":"2021-11-10T17:54:29.150Z","pid":9,"hostname":"a2a91d0441b8","name":"System","msg":"Exception while invoking method autoTranslate.getSupportedLanguages 'Error, too many requests. Please slow down. You must wait 48 seconds before trying again. [too-many-requests]'"}
{"level":50,"time":"2021-11-10T17:58:47.484Z","pid":9,"hostname":"a2a91d0441b8","name":"System","msg":"Exception while invoking method apps/go-enable 'TOTP Required [totp-required]'"}
And here is the Log from the mongodb-container:
2021-11-11T08:14:52.182+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:245 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 17 } }, ReplicationStateTransition: { acquireCount: { w: 17 } }, Global: { acquireCount: { w: 17 } }, Database: { acquireCount: { w: 17 } }, Collection: { acquireCount: { w: 17 } }, Mutex: { acquireCount: { r: 34 } } } flowControl:{ acquireCount: 17, timeAcquiringMicros: 6 } storage:{} protocol:op_msg 237ms
2021-11-11T08:24:52.142+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:245 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 17 } }, ReplicationStateTransition: { acquireCount: { w: 17 } }, Global: { acquireCount: { w: 17 } }, Database: { acquireCount: { w: 17 } }, Collection: { acquireCount: { w: 17 } }, Mutex: { acquireCount: { r: 34 } } } flowControl:{ acquireCount: 17, timeAcquiringMicros: 12 } storage:{} protocol:op_msg 197ms
2021-11-11T08:54:52.149+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:245 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 17 } }, ReplicationStateTransition: { acquireCount: { w: 17 } }, Global: { acquireCount: { w: 17 } }, Database: { acquireCount: { w: 17 } }, Collection: { acquireCount: { w: 17 } }, Mutex: { acquireCount: { r: 34 } } } flowControl:{ acquireCount: 17, timeAcquiringMicros: 8 } storage:{} protocol:op_msg 204ms
2021-11-11T09:14:52.389+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:245 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 17 } }, ReplicationStateTransition: { acquireCount: { w: 17 } }, Global: { acquireCount: { w: 17 } }, Database: { acquireCount: { w: 17 } }, Collection: { acquireCount: { w: 17 } }, Mutex: { acquireCount: { r: 34 } } } flowControl:{ acquireCount: 17, timeAcquiringMicros: 16 } storage:{} protocol:op_msg 443ms
2021-11-11T10:09:52.049+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:245 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 17 } }, ReplicationStateTransition: { acquireCount: { w: 17 } }, Global: { acquireCount: { w: 17 } }, Database: { acquireCount: { w: 17 } }, Collection: { acquireCount: { w: 17 } }, Mutex: { acquireCount: { r: 34 } } } flowControl:{ acquireCount: 17, timeAcquiringMicros: 9 } storage:{} protocol:op_msg 104ms
2021-11-11T10:19:52.051+0000 I COMMAND [LogicalSessionCacheRefresh] command config.$cmd command: update { update: "system.sessions", ordered: false, allowImplicitCollectionCreation: false, writeConcern: { w: "majority", wtimeout: 15000 }, $db: "config" } numYields:0 reslen:548 locks:{ ParallelBatchWriterMode: { acquireCount: { r: 20 } }, ReplicationStateTransition: { acquireCount: { w: 20 } }, Global: { acquireCount: { w: 20 } }, Database: { acquireCount: { w: 20 } }, Collection: { acquireCount: { w: 20 } }, Mutex: { acquireCount: { r: 40 } } } flowControl:{ acquireCount: 20, timeAcquiringMicros: 10 } storage:{} protocol:op_msg 105ms
