Logging in for this IP temporary not possible
I am running the latest snap 3.x version. I think 3.18.
I was working in the layout section and inserted some html for displaying a logo on the home page. The logo got displayed so the HTML was ok. After that I suddenly got logged out and got a notification that logging in for my IP was temporary disabled.
I tried other locations (different IP) same problem. Also all the users are not able to login. They get the same message.
Reboots, different browsers, same problem.
What I need is a way to switch off the block by IP option in the logs section. Does anyone know how I can change it in mongodb and by what command?
Thanks,
Stef
hi @chatdev ! Welcome to our forums!
All settings can be changed using the UI, the API or directly into the DB.
I usually go to the settings, let the mouse hover it for a while, and get the name. This one, for instance, is Block_Multiple_Failed_Logins_By_Ip
you can try changing it from the API or directly, for that, check this doc:
You can also use a software like Mongodb Compass to help you navigate into the database. The collection you are looking for is the rocketchat_settings
let me know if you were able to log in again.
Also:
You mean in the Admin > Account, right?
