Locked out by a two factor authentification loop
  • self-hosted rocketchat
  • enabled two factor authentification by email, and auto opt-in users to two factor auth
  • all users imported from an LDAP
  • SMTP email server settings are blank/unset
    => can’t set SMTP server settings, asking for code sent by email, that has never been sent
    => can’t disable two factor authentication, asking for code sent by email, that has never been sent
  • Version of Rocket.Chat Server: 3.6.3
  • Operating System: Debian 10
  • Deployment Method: tar
Is there any way to disable via a config file / db the two factor authentication ?
Found a way myself.
Use Mongodb shell to do those queries :
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_Enabled”},{$set: {“packageValue” : false}});
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_Enabled”},{$set: {“value” : false}});
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_By_Email_Enabled”},{$set: {“packageValue” : false}});
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_By_Email_Enabled”},{$set: {“value” : false}});
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_Enforce_Password_Fallback”},{$set: {“packageValue” : false}});
db.rocketchat_settings.update({“_id” : “Accounts_TwoFactorAuthentication_Enforce_Password_Fallback”},{$set: {“value” : false}});
I’m in exactly the same position with my Snap deployed server. SMTP server is no longer connecting, so I’m not getting any of the 2FA emails that I need so I can turn 2FA off!
Any chance there’s a Snap config command to turn 2FA off? Or is your method, @Alicya, somehow applicable to a Snap deployment?
I don’t know. Good luck.
Thanks man, perfect response
Hi @Alicya ,
I can not connect to mongodb since I installed rocketchat with snap.
Is there any other way to use the queries?
Thank you!
Just for reference, if you installed a snap on ubuntu like this, and using @Alicya 's magic recipe, here’s how you access the local mongo db:
/snap/rocketchat-server/current/bin/mongo
Then run
use parties;
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_Enabled"},{$set: {"packageValue" : false}});
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_Enabled"},{$set: {"value" : false}});
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_By_Email_Enabled"},{$set: {"packageValue" : false}});
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_By_Email_Enabled"},{$set: {"value" : false}});
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_Enforce_Password_Fallback"},{$set: {"packageValue" : false}});
db.rocketchat_settings.update({"_id" : "Accounts_TwoFactorAuthentication_Enforce_Password_Fallback"},{$set: {"value" : false}});
