Kubernetes AWS & LoadBalancers?
Hello, I am trying to launch rocket chat within our Kubernetes cluster hosted on AWS EKS. I am able to deploy the app and access the application though kubectl’s prot-forward mechanism .
loclahost:8888 → localhost:3000
My issues is that when I try to set the application up behind a Network LoadBalancer the application does not load. Even when I create a route53 DNS record for rocket chat and point it at the load balancer the application will not load. The command I used to install the helm chart was the following.
helm install dev rocketchat/rocketchat \
--set mongodb.auth.password=<Password1> \
--set mongodb.auth.rootPassword=<Password2> \
--set mongodb.auth.username=rocketchat \
--set host=<DNS  Name in Route53> \
--set ingress.enabled=true \
--set service.type=LoadBalancer \
--set service.port=80 \
--set service.annotations."service\.beta\.kubernetes\.io/aws-load-balancer-type"=nlb-ip \
--set service.annotations."service\.beta\.kubernetes\.io/aws-load-balancer-proxy-protocol"=* \
--set service.annotations."service\.beta\.kubernetes\.io/aws-load-balancer-scheme"=internet-facing
Any help on this subject would be very helpful.
Thanks,
Edwin M.
Rocket.Chat Version: 4.5.2
NodeJS Version: 14.18.3 - x64
MongoDB Version: 4.4.11
MongoDB Engine: unknown
Platform: linux
Process Port: 3000
Site URL: http://:8080
ReplicaSet OpLog: Enabled
Commit Hash: ed2cb3fe61
Commit Branch: HEAD
Deployment Method: Kubernetes
Proxy: AWS Network LB
