Briefly about my RocketChat setup. It situated behind Proxy. Also it works under docker. Issues begin at this place. In order to send message to mobile client I have to use HTTP(s)_PROXY settings and it works fine. Anothe task is launch two Rocket.Chat instances. If HTTP_PROXY settings are “on”, they cannot communicate each other because all requests forward to proxy. In other hand, if HTTP_PROXY to turn off then Instances speak each other, but Rocket.Chat cannot send any messages to mobile clients.
Need help! May be somebody know how to configure chat that both features work simultaniously?
- Version of Rocket.Chat Server: 3.0.1
- Deployment Method: docker
- DB Replicaset Oplog: enable
- NodeJS Version: 12.14.0
- MongoDB Version: 4.0.12
- NPM: 6.13.4
Here my docker-compose.yml
version: '2'
services:
rocketchat:
image: rocketchat/rocket.chat:3.0.1
command: >
bash -c
"for i in `seq 1 30`; do
node main.js &&
s=$$? && break || s=$$?;
sleep 5;
done; (exit $$s)"
restart: unless-stopped
volumes:
- ./uploads:/app/uploads
- PORT=3000
- ROOT_URL=http://chat.example.loc:3000
- HTTP_PROXY=http://proxy.example.loc:3128
- HTTPS_PROXY=http://proxy.example.loc:3128
- INSTANCE_IP=rocketchat
depends_on:
- mongo
ports:
- 3000:3000
networks:
- chat_net
rocketchat2:
command: >
bash -c
node main.js &&
sleep 5;
done; (exit $$s)"
volumes:
- ./uploads2:/app/uploads
- PORT=3000
- INSTANCE_IP=rocketchat2
depends_on:
- mongo
ports:
- 3001:3000
networks:
- chat_net
mongo:
image: mongo:4.0
volumes:
- ./data/db:/data/db
- ./data/dump:/dump
networks:
- chat_net
networks:
chat_net:
