Hello guys,
I am trying to deploy RocketChat and MongoDB on different Hosts with Docker.
RocketChat on Host 192.168.56.11
MongoDB on Host 192.168.56.22
I am using the commands specified in here: https://hub.docker.com/_/rocket-chat
$ docker run --name db -d mongo:4.0 --smallfiles --replSet rs0 --oplogSize 128
$ docker exec -ti db mongo --eval “printjson(rs.initiate())”
Now im struggling with this part:
If you’re using a third party Mongo provider, or working with Kubernetes, you need to override the MONGO_URL environment variable:
$ docker run --name rocketchat -p 80:3000 --env ROOT_URL=http://localhost --env MONGO_URL=mongodb://mymongourl/mydb --env MONGO_OPLOG_URL=mongodb://mymongourl:27017/local -d rocket.chat
I followed this topic, which is similar with a different deployment method: How configure Rocket Chat and MongoDB in separatelly hosts?
So first I tried to deploy RC by using following parameters:
MONGO_URL=mongodb://192.168.56.22:27017/rocketchat?replicaSet=rs0
MONGO_OPLOG_URL=mongodb://192.168.56.22:27017/local?replicaSet=rs0
and also
Both versions gives me an error.
I also tried changing the mongod.conf within the container to:
net:
port: 27017
bindIp: 0.0.0.0 ##normally its 127.0.0.1
How can I define a specific container for these parameters?
I would be very thankful for any help.
- Operating System: Ubuntu 18.04
- Deployment Method: Docker
- Number of Running Instances: one on each host
- DB Replicaset Oplog: enabled
- NodeJS Version: 12.16.1 - x64
- MongoDB Version: 4.0.20
- Proxy: nginx
- Firewalls involved: none
