How to use Jira Webhook?
I’m trying to setup the Jira integration as described here. I’m using the script linked on the page from GitHub.
I want to post in the private group #rocket.chat_debug and also tried with #general.
When running the curl command, there’s no failure in the logs, but also no message in the channel #rocket.chat_debug.
In the Jira logs, there is a warning:
2020-09-28 13:08:58,758 httpclient-callbacks:thread-8 WARN anonymous [c.a.webhooks.plugin.PublishTaskFactoryImpl$PublishTaskImpl] Client error - 400 when posting to web hook at ‘https://rocketchat-server/hooks/F23u4CY7wrQMnekzj/vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32’
Anyone here who has successfully set up this Webhook? The script is quite old, maybe it doesn’t work anymore and isn’t processing the data from Jira correctly!?
  • Version of Rocket.Chat Server: 3.6.3
  • Operating System: Debian
  • Deployment Method: docker
  • NodeJS Version: 12.16.1
  • MongoDB Version: 4.0.16
  • Proxy: Citrix ADC
  • Firewalls involved: -
This is what I get in the RC logs, when using the curl statement from the integration page:
I20200928-11:04:29.903(0) server.js:204 API ➔ debug POST: /hooks/F23u4CY7wrQMnekzj/vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32
I20200928-11:04:29.904(0) server.js:204 Integrations ➔ Incoming WebHook.info Post integration: gpmuser
I20200928-11:04:29.905(0) server.js:204 Integrations ➔ Incoming WebHook.debug @urlParams: { integrationId: ‘F23u4CY7wrQMnekzj’, token: ‘vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32’ }
I20200928-11:04:29.906(0) server.js:204 Integrations ➔ Incoming WebHook.debug @bodyParams: { text: ‘Test mit curl’, attachments: [ { title: ‘Rocket.Chat’, title_link: ‘https://rocket.chat’, text: ‘Rocket.Chat, the best open source chat’, image_url: ‘/images/integration-attachment-example.png’, color: ‘#764FA5’ } ] }
I20200928-11:04:29.913(0) server.js:204 Integrations ➔ Incoming WebHook.debug [Process Incoming Request result of Trigger gpmuser :] No data
I20200928-11:04:29.914(0) server.js:204 API ➔ debug Success { statusCode: 200, body: { success: true } }
This is what I get in the RC logs, when triggering the webhook from Jira:
I20200928-11:08:23.521(0) server.js:204 API ➔ debug GET: /api/v1/integrations.list?query={%22name%22:{%22$regex%22:%22%22,%22$options%22:%22i%22}}&sort={%22name%22:1}&count=25
I20200928-11:08:30.303(0) server.js:204 API ➔ debug GET: /api/v1/integrations.get?integrationId=F23u4CY7wrQMnekzj
I20200928-11:08:30.308(0) server.js:204 API ➔ debug Success { statusCode: 200, body: { integration: { _id: ‘F23u4CY7wrQMnekzj’, enabled: true, channel: [Array], username: ‘rc.user’, name: ‘gpmuser’, alias: ‘’, avatarUrl: ‘’, emoji: ‘’, scriptEnabled: true, script: ‘/jshint esnext:true/
’ + ‘const DESC_MAX_LENGTH = 140;
’ + “const JIRA_LOGO = ‘data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAACRElEQVRYhb/jIXDkk+pgAAAABJRU5ErkJggg==’;
” + ‘function stripDesc(str) {
’ + “\treturn (str && str.length > DESC_MAX_LENGTH) ? str.slice(0, DESC_MAX_LENGTH - 3) + ‘…’ : str;
’ + ‘function prepareAttachment({issue, user}, text) {
’ + ‘\tlet issueType = issue.fields.issuetype;
’ + ‘\tlet res = {
’ + ‘\t\tauthor_name: user.displayName
’ + “\t\t, author_icon: user.avatarUrls[‘24x24’]
” + ‘\t\t, thumb_url: issueType.iconUrl
’ + ‘\t};
’ + ‘\tif (text) {
’ + “\t\ttext = text.replace(/\{\{(user|issue)\.([^a-z_0-9]+)\}\}/g, (m, type, key) => (type===‘user’ ? user : issue)[key]);
” + ‘\t\tres.text = text;
’ + ‘\t}
’ + ‘\treturn res;
’ + ‘class Script {
’ + ‘\tprocess_incoming_request({request}) {
’ + ‘\t\tconst data = request.content;
’ + ‘\t\ttry {
’ + “\t\t\tif (!data.issue || (data.user && data.user.name === ‘gitlab’)) {
” + ‘\t\t\t\treturn;
’ + ‘\t\t\t}
’ + ‘\t\t\tlet issue = data.issue;
’ + “\t\t\tlet baseJiraUrl = issue.self.replace(/\/rest\/./, '');<br>" + '\t\t\tlet user = data.user;<br>' + "\t\t\tlet assignedTo = (issue.fields.assignee && issue.fields.assignee.name !== user.name) ? `, assigned to {issue.fields.assignee.displayName}: '';<br>" + "\t\t\tlet issueSummary =${issue.key} {issue.fields.summary} _({issue.fields.priority.name.replace(/^\s\d*\.\s*/, ‘’)}{assignedTo})_`;<br>" + '\t\t\tlet message = {<br>' + "\t\t\t\ticon_url: (issue.fields.project && issue.fields.project.avatarUrls && issue.fields.project.avatarUrls['48x48']) || JIRA_LOGO<br>" + '\t\t\t\t, attachments: []<br>' + '\t\t\t};<br>' + '<br>' + "\t\t\tif (data.webhookEvent === 'jira:issue_created') {<br>" + '\t\t\t\tmessage.attachments.push(prepareAttachment(data, `*Created* {issueSummary}:<br>{stripDesc(issue.fields.description)}`));<br>' + "\t\t\t} else if (data.webhookEvent === 'jira:issue_deleted') {<br>" + '\t\t\t\tmessage.attachments.push(prepareAttachment(data, `*Deleted* {issueSummary}));<br>' + "\t\t\t} else if (data.webhookEvent === 'jira:issue_updated') {<br>" + '\t\t\t\tif (data.changelog && data.changelog.items) { // field update<br>' + '\t\t\t\t\tlet logs = [];<br>' + '\t\t\t\t\tdata.changelog.items.forEach((change) => {<br>' + "\t\t\t\t\t\tif (!change.field.match('status|resolution|comment|priority') ) {<br>" + '\t\t\t\t\t\t\treturn;<br>' + '\t\t\t\t\t\t}<br>' + "\t\t\t\t\t\tif (change.field==='description') {<br>" + '\t\t\t\t\t\t\tlogs.push(Changed description to:<br>{stripDesc(change.toString)}`);<br>' + '\t\t\t\t\t\t} else {<br>' + '\t\t\t\t\t\t\tlogs.push(`*{change.field}* changed from {change.fromString} to *{change.toString});<br>' + '\t\t\t\t\t\t}<br>' + '\t\t\t\t\t});<br>' + "\t\t\t\t\tlogs.length && message.attachments.push(prepareAttachment(data, Updated {issueSummary}:\<br> - {logs.join(’<br> - ')}));<br>" + '\t\t\t\t}<br>' + '<br>' + '\t\t\t\tif (data.comment) { // comment update<br>' + '\t\t\t\t\tlet comment = data.comment;<br>' + "\t\t\t\t\tlet action = comment.created !== comment.updated ? 'Updated comment' : 'Commented';<br>" + '\t\t\t\t\tmessage.attachments.push(prepareAttachment(data, {action}* on {issueSummary}:<br>{stripDesc(comment.body)}`));<br>' + '\t\t\t\t}<br>' + '\t\t\t}<br>' + '<br>' + '\t\t\tif (message.text || message.attachments.length) {<br>' + '\t\t\t\treturn {content:message};<br>' + '\t\t\t}<br>' + '\t\t} catch(e) {<br>' + "\t\t\tconsole.log('jiraevent error', e);<br>" + '\t\t\treturn {<br>' + '\t\t\t\terror: {<br>' + '\t\t\t\t\tsuccess: false,<br>' + '\t\t\t\t\tmessage: `{e.message || e} {JSON.stringify(data)}`<br>' + '\t\t\t\t}<br>' + '\t\t\t};<br>' + '\t\t}<br>' + '\t}<br>' + '}', type: 'webhook-incoming', scriptCompiled: 'var DESC_MAX_LENGTH=140;var JIRA_LOGO="data:image/png;base64,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";function stripDesc(str){return str&&str.length>DESC_MAX_LENGTH?str.slice(0,DESC_MAX_LENGTH-3)+"...":str}function prepareAttachment(_ref,text){var issue=_ref.issue,user=_ref.user;var issueType=issue.fields.issuetype;var res={author_name:user.displayName,author_icon:user.avatarUrls["24x24"],thumb_url:issueType.iconUrl};if(text){text=text.replace(/\\{\\{(user|issue)\\.([^a-z_0-9]+)\\}\\}/g,function(m,type,key){return(type==="user"?user:issue)[key]});res.text=text}return res}var Script=function(){function Script(){}var _proto=Script.prototype;_proto.process_incoming_request=function process_incoming_request(_ref2){var request=_ref2.request;var data=request.content;try{if(!data.issue||data.user&&data.user.name==="gitlab"){return}var issue=data.issue;var baseJiraUrl=issue.self.replace(/\\/rest\\/.*/,”");var user=data.user;var assignedTo=issue.fields.assignee&&issue.fields.assignee.name!==user.name?", assigned to “+issue.fields.assignee.displayName:”";var issueSummary=""+issue.key+" “+issue.fields.summary+” ("+issue.fields.priority.name.replace(/^\s*\d*\.\s*/,"")+assignedTo+")";var message={icon_url:issue.fields.project&&issue.fields.project.avatarUrls&&issue.fields.project.avatarUrls[“48x48”]||JIRA_LOGO,attachments:};if(data.webhookEvent===“jira:issue_created”){message.attachments.push(prepareAttachment(data,“Created “+issueSummary+”:<br>”+stripDesc(issue.fields.description)))}else if(data.webhookEvent===“jira:issue_deleted”){message.attachments.push(prepareAttachment(data,“Deleted “+issueSummary))}else if(data.webhookEvent===“jira:issue_updated”){if(data.changelog&&data.changelog.items){var logs=;data.changelog.items.forEach(function(change){if(!change.field.match(“status|resolution|comment|priority”)){return}if(change.field===“description”){logs.push(“Changed description to:<br>”+stripDesc(change.toString))}else{logs.push(”"+change.field+" changed from “+change.fromString+” to “+change.toString+””)}});logs.length&&message.attachments.push(prepareAttachment(data,“Updated “+issueSummary+”:<br> - “+logs.join(”<br> - “)))}if(data.comment){var comment=data.comment;var action=comment.created!==comment.updated?“Updated comment”:“Commented”;message.attachments.push(prepareAttachment(data,”"+action+" on “+issueSummary+”:<br>”+stripDesc(comment.body)))}}if(message.text||message.attachments.length){return{content:message}}}catch(e){console.log(“jiraevent error”,e);return{error:{success:false,message:(e.message||e)+" “+JSON.stringify(data)}}}};return Script}();’, token: ‘vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32’, userId: ‘aBPPdyb9zSLxeRpLw’, _createdAt: 2020-09-28T07:35:07.407Z, _createdBy: [Object], _updatedAt: 2020-09-28T10:29:08.662Z, _updatedBy: [Object] }, success: true } }
I20200928-11:08:45.924(0) server.js:204 Meteor ➔ method readMessages -> userId: GY56GR6i9jCmEnthd, arguments: [“p3paZ7DXR6gPKkEcX”]
I20200928-11:08:46.929(0) server.js:204 Meteor ➔ method UserPresence:online -> userId: GY56GR6i9jCmEnthd, arguments: [{}]
I20200928-11:08:58.923(0) server.js:204 API ➔ debug POST: /hooks/F23u4CY7wrQMnekzj/vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32?user_id=rc.user%40meinemail.net&user_key=rc.user%40meinemail.net
I20200928-11:08:58.924(0) server.js:204 Integrations ➔ Incoming WebHook.info Post integration: gpmuser
I20200928-11:08:58.925(0) server.js:204 Integrations ➔ Incoming WebHook.debug @urlParams: { integrationId: ‘F23u4CY7wrQMnekzj’, token: ‘vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32’ }
I20200928-11:08:58.926(0) server.js:204 Integrations ➔ Incoming WebHook.debug @bodyParams: { timestamp: 1601291338508, webhookEvent: ‘comment_created’, comment: { self: ‘https://jira-server/rest/api/2/issue/15452/comment/14515’, id: ‘14515’, author: { self: ‘https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net’, name: ‘user@meinemail.net’, key: ‘user@meinemail.net’, avatarUrls: [Object], displayName: ‘Vorname Nachname’, active: true, timeZone: ‘Europe/Berlin’ }, body: ‘sfdsfd’, updateAuthor: { self: ‘https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net’, name: ‘user@meinemail.net’, key: ‘user@meinemail.net’, avatarUrls: [Object], displayName: ‘Vorname Nachname’, active: true, timeZone: ‘Europe/Berlin’ }, created: ‘2020-09-28T13:08:58.508+0200’, updated: ‘2020-09-28T13:08:58.508+0200’ } }
I20200928-11:08:58.932(0) server.js:204 Integrations ➔ Incoming WebHook.debug [Process Incoming Request result of Trigger gpmuser :] No data
I20200928-11:08:58.933(0) server.js:204 API ➔ debug Success { statusCode: 200, body: { success: true } }
I20200928-11:08:59.097(0) server.js:204 API ➔ debug POST: /hooks/F23u4CY7wrQMnekzj/vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32?user_id=rc.user%40meinemail.net&user_key=rc.user%40meinemail.net
I20200928-11:08:59.098(0) server.js:204 Integrations ➔ Incoming WebHook.info Post integration: gpmuser
I20200928-11:08:59.101(0) server.js:204 Integrations ➔ Incoming WebHook.debug @urlParams: { integrationId: ‘F23u4CY7wrQMnekzj’, token: ‘vGNMrbYKuBMepqa7ec7xYN7qiDxptbNiNzwuSGDCWDRywq32’ }
I20200928-11:08:59.102(0) server.js:204 Integrations ➔ Incoming WebHook.debug @bodyParams: { timestamp: 1601291338508, webhookEvent: ‘jira:issue_updated’, issue_event_type_name: ‘issue_commented’, user: { self: ‘https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net’, name: ‘user@meinemail.net’, key: ‘user@meinemail.net’, emailAddress: ‘user@meinemail.net’, avatarUrls: { ‘48x48’: ‘https://jira-server/secure/useravatar?ownerId=rc.user%40meinemail.net&avatarId=11600’, ‘24x24’: ‘https://jira-server/secure/useravatar?size=small&ownerId=rc.user%40meinemail.net&avatarId=11600’, ‘16x16’: ‘https://jira-server/secure/useravatar?size=xsmall&ownerId=rc.user%40meinemail.net&avatarId=11600’, ‘32x32’: ‘https://jira-server/secure/useravatar?size=medium&ownerId=rc.user%40meinemail.net&avatarId=11600’ }, displayName: ‘Vorname Nachname’, active: true, timeZone: ‘Europe/Berlin’ }, issue: { id: ‘15452’, self: ‘https://jira-server/rest/api/2/issue/15452’, key: ‘GPMUSER-502’, fields: { fixVersions: , resolution: null, customfield_10105: ‘0|i00n33:’, customfield_10900: null, customfield_10901: null, customfield_10902: ‘verena@mailadr.net’, customfield_10903: ‘Da ich an einer Schulung teilnehme \r
’ + ‘Ufg \r
’, customfield_10904: ‘Schaller’, customfield_10905: ‘Verena’, customfield_10906: [Array], customfield_10907: ‘08999911211’, customfield_10908: ‘Nicole’, customfield_10909: ‘Nachname’, lastViewed: ‘2020-09-28T12:23:33.067+0200’, customfield_10100: null, customfield_10101: null, timeestimate: null, aggregatetimeoriginalestimate: null, versions: , issuelinks: , assignee: [Object], status: [Object], customfield_11300: null, customfield_11413: null, aggregatetimeestimate: null, creator: [Object], subtasks: , reporter: [Object], aggregateprogress: [Object], customfield_10200: null, customfield_10201: null, customfield_11412: null, customfield_10202: null, customfield_10313: null, customfield_11403: null, customfield_10314: null, customfield_11402: null, customfield_11404: null, customfield_11406: null, customfield_11409: null, customfield_11408: {summaryBean=com.atlassian.jira.plugin.devstatus.rest.SummaryBean@4c5ad470[summary={pullrequest=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@64363282[overall=PullRequestOverallBean{stateCount=0, state='OPEN', details=PullRequestOverallDetails{openCount=0, mergedCount=0, declinedCount=0}},byInstanceType={}], build=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@67e83c92[overall=com.atlassian.jira.plugin.devstatus.summary.beans.BuildOverallBean@329fa0cf[failedBuildCount=0,successfulBuildCount=0,unknownBuildCount=0,count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], review=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@114d2c2[overall=com.atlassian.jira.plugin.devstatus.summary.beans.ReviewsOverallBean@20ce9fc1[stateCount=0,state=<null>,dueDate=<null>,overDue=false,count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], deployment-environment=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6642be6[overall=com.atlassian.jira.plugin.devstatus.summary.beans.DeploymentOverallBean@49326a3d[topEnvironments=[],showProjects=false,successfulCount=0,count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], repository=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6e17331b[overall=com.atlassian.jira.plugin.devstatus.summary.beans.CommitOverallBean@3af3998f[count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], branch=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@1defae2c[overall=com.atlassian.jira.plugin.devstatus.summary.beans.BranchOverallBean@47d65c2e[count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}]},errors=[],configErrors=[]], devSummaryJson={"cachedValue":{"errors":[],"configErrors":[],"summary":{"pullrequest":{"overall":{"count":0,"lastUpdated":null,"stateCount":0,"state":"OPEN","details":{"openCount":0,"mergedCount":0,"declinedCount":0,"total":0},"open":true},"byInstanceType":{}},"build":{"overall":{"count":0,"lastUpdated":null,"failedBuildCount":0,"successfulBuildCount":0,"unknownBuildCount":0},"byInstanceType":{}},"review":{"overall":{"count":0,"lastUpdated":null,"stateCount":0,"state":null,"dueDate":null,"overDue":false,"completed":false},"byInstanceType":{}},"deployment-environment":{"overall":{"count":0,"lastUpdated":null,"topEnvironments":[],"showProjects":false,"successfulCount":0},"byInstanceType":{}},"repository":{"overall":{"count":0,"lastUpdated":null},"byInstanceType":{}},"branch":{"overall": environment=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@39508473[overall=com.atlassian.jira.plugin.devstatus.summary.beans.DeploymentOverallBean@1664b28[topEnvironments=[],showProjects=false,successfulCount=0,count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], repository=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6f8696ac[overall=com.atlassian.jira.plugin.devstatus.summary.beans.CommitOverallBean@575c67b7[count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}], branch=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6a921233[overall=com.atlassian.jira.plugin.devstatus.summary.beans.BranchOverallBean@599e2b42[count=0,lastUpdated=<null>,lastUpdatedTimestamp=<null>],byInstanceType={}]},errors=[],configErrors=[]], devSummaryJson={"cachedValue":{"errors":[],"configErrors":[],"summary":{"pullrequest":{"overall":{"count":0,"lastUpdated":null,"stateCount":0,"state":"OPEN","details":{"openCount":0,"mergedCount":0,"declinedCount":0,"total":0},"open":true},"byInstanceType":{}},"build":{"overall":{"count":0,"lastUpdated":null,"failedBuildCount":0,"successfulBuildCount":0,"unknownBuildCount":0},"byInstanceType":{}},"review":{"overall":{"count":0,"lastUpdated":null,"stateCount":0,"state":null,"dueDate":null,"overDue":false,"completed":false},"byInstanceType":{}},"deployment-environment":{"overall":{"count":0,"lastUpdated":null,"topEnvironments":[],"showProjects":false,"successfulCount":0},"byInstanceType":{}},"repository":{"overall":{"count":0,"lastUpdated":null},"byInstanceType":{}},"branch":{"overall":{"count":0,"lastUpdated":null},"byInstanceType":{}}}},"isStale":false}}, customfield_11204: null, environment: null, customfield_10910: ‘nicole.schaller@lfst.bayern.de’, customfield_10911: null, duedate: null, comment: [Object] } }, comment: { self: ‘https://jira-server/rest/api/2/issue/15452/comment/14515’, id: ‘14515’, author: { self: ‘https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net’, name: ‘user@meinemail.net’, key: ‘user@meinemail.net’, emailAddress: ‘user@meinemail.net’, avatarUrls: [Object], displayName: ‘Vorname Nachname’, active: true, timeZone: ‘Europe/Berlin’ }, body: ‘sfdsfd’, updateAuthor: { self: ‘https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net’, name: ‘user@meinemail.net’, key: ‘user@meinemail.net’, emailAddress: ‘user@meinemail.net’, avatarUrls: [Object], displayName: ‘Vorname Nachname’, active: true, timeZone: ‘Europe/Berlin’ }, created: ‘2020-09-28T13:08:58.508+0200’, updated: ‘2020-09-28T13:08:58.508+0200’ } }
I20200928-11:08:59.106(0) jiraevent error TypeError: Cannot read property ‘name’ of undefined at Script.process_incoming_request (script.js:1:1930) at evalmachine.:6:23
I20200928-11:08:59.109(0) server.js:204 API ➔ debug Failure { statusCode: 400, body: { success: false, message: `Cannot read property ‘name’ of undefined {“timestamp”:1601291338508,“webhookEvent”:“jira:issue_updated”,“issue_event_type_name”:“issue_commented”,“user”:{“self”:“https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net",“name”:“user@meinemail.net”,“key”:“user@meinemail.net”,“emailAddress”:“user@meinemail.net”,“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=rc.user%40meinemail.net&avatarId=11600”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=rc.user%40meinemail.net&avatarId=11600”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=rc.user%40meinemail.net&avatarId=11600”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=rc.user%40meinemail.net&avatarId=11600”},“displayName”:"Vorname Nachname”,“active”:true,“timeZone”:“Europe/Berlin”},“issue”:{“id”:“15452”,“self”:“https://jira-server/rest/api/2/issue/15452",“key”:“GPMUSER-502”,“fields”:{“fixVersions”:[],“resolution”:null,“customfield_10105”:“0|i00n33:”,“customfield_10900”:null,“customfield_10901”:null,“customfield_10902”:“verena@mailadr.net”,“customfield_10903”:"Da ich an einer Schulung teilnehme \r<br>”,“customfield_10904”:“Weiter Text”,“customfield_10905”:“Verena”,“customfield_10906”:[{“self”:“https://jira-server/rest/api/2/customFieldOption/10803",“value”:“ADONIS”,“id”:“10803”}],“customfield_10907”:“08999911211”,“customfield_10908”:“Nicole”,“customfield_10909”:“Nachname”,“lastViewed”:“2020-09-28T12:23:33.067+0200”,“customfield_10100”:null,“customfield_10101”:null,“timeestimate”:null,“aggregatetimeoriginalestimate”:null,“versions”:[],“issuelinks”:[],“assignee”:{“self”:“https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net”,“name”:“user@meinemail.net”,“key”:“user@meinemail.net”,“emailAddress”:“user@meinemail.net”,“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=rc.user%40meinemail.net&avatarId=11600”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=rc.user%40meinemail.net&avatarId=11600”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=rc.user%40meinemail.net&avatarId=11600”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=rc.user%40meinemail.net&avatarId=11600”},“displayName”:"Vorname Nachname”,“active”:true,“timeZone”:“Europe/Berlin”},“status”:{“self”:“https://jira-server/rest/api/2/status/10400",“description”:"Die Voraussetzung für die weitere Bearbeitung dieses Vorgangs wurde erstellt.”,“iconUrl”:“https://jira-server/images/icons/statuses/generic.png",“name”:“Erstellt”,“id”:“10400”,“statusCategory”:{“self”:“https://jira-server/rest/api/2/statuscategory/2”,“id”:2,“key”:“new”,“colorName”:“blue-gray”,“name”:“Aufgaben”}},“customfield_11300”:null,“customfield_11413”:null,“aggregatetimeestimate”:null,“creator”:{“self”:“https://jira-server/rest/api/2/user?username=system.benutzer%40meinemail.net”,“name”:“system.benutzer@meinemail.net”,“key”:“system.benutzer@meinemail.net”,“emailAddress”:"",“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=system.benutzer%40meinemail.net&avatarId=10903”},“displayName”:"System Benutzer”,“active”:true,“timeZone”:“Europe/Berlin”},“subtasks”:,“reporter”:{“self”:“https://jira-server/rest/api/2/user?username=system.benutzer%40meinemail.net",“name”:“system.benutzer@meinemail.net”,“key”:“system.benutzer@meinemail.net”,“emailAddress”:"",“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=system.benutzer%40meinemail.net&avatarId=10903”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=system.benutzer%40meinemail.net&avatarId=10903”},“displayName”:"System Benutzer”,“active”:true,“timeZone”:“Europe/Berlin”},“aggregateprogress”:{“progress”:0,“total”:0},“customfield_10200”:null,“customfield_10201”:null,“customfield_11412”:null,“customfield_10202”:null,“customfield_10313”:null,“customfield_11403”:null,“customfield_10314”:null,“customfield_11402”:null,“customfield_11404”:null,“customfield_11406”:null,“customfield_11409”:null,“customfield_11408”:”{summaryBean=com.atlassian.jira.plugin.devstatus.rest.SummaryBean@4c5ad470[summary={pullrequest=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@64363282[overall=PullRequestOverallBean{stateCount=0, state=‘OPEN’, details=PullRequestOverallDetails{openCount=0, mergedCount=0, declinedCount=0}},byInstanceType={}], build=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@67e83c92[overall=com.atlassian.jira.plugin.devstatus.summary.beans.BuildOverallBean@329fa0cf[failedBuildCount=0,successfulBuildCount=0,unknownBuildCount=0,count=0,lastUpdated=,lastUpdatedTimestamp=],byInstanceType={}], review=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@114d2c2[overall=com.atlassian.jira.plugin.devstatus.summary.beans.ReviewsOverallBean@20ce9fc1[stateCount=0,state=,dueDate=,overDue=false,count=0,lastUpdated=,lastUpdatedTimestamp=],byInstanceType={}], deployment-environment=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6642be6[overall=com.atlassian.jira.plugin.devstatus.summary.beans.DeploymentOverallBean@49326a3d[topEnvironments=,showProjects=false,successfulCount=0,count=0,lastUpdated=,lastUpdatedTimestamp=],byInstanceType={}], repository=com.atlassian.jira.plugin.devstatus.rest.SummaryItemBean@6e17331b[overall=com.atlassian.jira.plugin.devstatus.summary.beans.CommitOverallBean@3af3998f[count=0,lastUpdated=,lastUpdatedTimestamp=],byInstanceType={}], b
\":false}}",“customfield_11204”:null,“environment”:null,“customfield_10910”:"nicole.schaller@lfst.bayern.de",“customfield_10911”:null,“duedate”:null,“comment”:{“comments”:[{“self”:“https://jira-server/rest/api/2/issue/15452/comment/14391",“id”:“14391”,“author”:{“self”:“https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net”,“name”:“user@meinemail.net”,“key”:“user@meinemail.net”,“emailAddress”:“user@meinemail.net”,“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=rc.user%40meinemail.net&avatarId=11600”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=rc.user%40meinemail.net&avatarId=11600”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=rc.user%40meinemail.net&avatarId=11600”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=rc.user%40meinemail.net&avatarId=11600”},“displayName”:"Vorname Nachname”,“active”:true,“timeZone”:“Europe/Berlin”},“body”:"[~robert.werner@meinemail.net] [~anderer.user@meinemail.net] Zum ersten Mal jemand mit einem solchen Wunsch.\r<br>\r<br>Wie verfahrt ihr denn hier sonst? Sollen solche Anmeldungen hier auch durch? Oder gab es nicht Schulungsuser?\r<br>\r<br>Wenn die hier nicht durchlaufen sollen/müssen, würde ich das auf der Plattformseite vermerken…",“updateAuthor”:{“self”:“https://jira-server/rest/api/2/user?username=rc.user%40meinemail.net",“name”:“user@meinemail.net”,“key”:“user@meinemail.net”,“emailAddress”:“user@meinemail.net”,“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=rc.user%40meinemail.net&avatarId=11600”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=rc.user%40meinemail.net&avatarId=11600”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=rc.user%40meinemail.net&avatarId=11600”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=rc.user%40meinemail.net&avatarId=11600”},“displayName”:"Vorname Nachname”,“active”:true,“timeZone”:“Europe/Berlin”},“created”:“2020-09-25T09:03:46.000+0200”,“updated”:“2020-09-25T09:03:46.000+0200”},{“self”:“https://jira-server/rest/api/2/issue/15452/comment/14500",“id”:“14500”,“author”:{“self”:“https://jira-server/rest/api/2/user?username=anderer.user%40meinemail.net”,“name”:“anderer.user@meinemail.net”,“key”:“anderer.user@meinemail.net”,“emailAddress”:“anderer.user@meinemail.net”,“avatarUrls”:{“48x48”:“https://jira-server/secure/useravatar?ownerId=anderer.user%40meinemail.net&avatarId=11504”,“24x24”:“https://jira-server/secure/useravatar?size=small&ownerId=anderer.user%40meinemail.net&avatarId=11504”,“16x16”:“https://jira-server/secure/useravatar?size=xsmall&ownerId=anderer.user%40meinemail.net&avatarId=11504”,“32x32”:“https://jira-server/secure/useravatar?size=medium&ownerId=anderer.user%40meinemail.net&avatarId=11504”},“displayName”:"Joachim Borchers”,“active”:true,“timeZone”:“Europe/Berlin”},“body”:"
Nachname",“active”:true,“timeZone”:“Europe/Berlin”},“created”:“2020-09-28T13:08:58.508+0200”,“updated”:“2020-09-28T13:08:58.508+0200”}}` } }
Ok, I got it.
But I had to use the script from this Github issue: https://github.com/RocketChat/Rocket.Chat/issues/14760
