Hi guys, I want to set the LDAP_Encryption method to “StartTLS” via docker environment variable. The keyname for that is LDAP_Encryption. But how to set the value? “StartTLS” as value does not work.
Hi @dbluxo!
How did you solve this problem?
the value is “tls”. Unfortunately those values are not documented. I have inspected the Admin Interface in Browser and found the value:
Hi @dbluxo!
Thnak you man!
