Hiring dev to build a new mobile first webapp on top of RC
We are building a mobile first-webapp on top of RC for our small community. The features needed are quite simple in nowadays standard :
  • Blog module
  • Media ( photo + clip)
  • few other CRUD-like feature.
We need 1 dev mostly for building the front end but being able to implement backend code is also needed from time to time.
It is a longterm project but Phrase 1 of the project is about demoing
  1. the landing page
  2. blog module + comment
  3. simplified version of other modules
    Details are described here :
    https://balsamiq.cloud/s67pkf2/pwbgoy8/r6B57
Code requirement:
  • Base on the latest source code from RC github
  • Follow coding standard from RC (which is migrating to typescript + react)
  • Able to merge future code from RC github (if possible)
If you are interest, please email me your estimation for the phrase 1 above (time & $ ), via email bqt.ctt [@t] outlook [d0t] com.
Thanks
I would be glad to assist you.
To discuss further in detail kindly reach me at garry@cisinlabs.com or Skype me: cis.garry
Looking forward for your response.
Thanks
Garry
Hello Garry,
I am glad you are interested.
I am sending you an email.
Thanks
Hello @tran.thi.hanh
Please drop an email to [Tarun.lashkari@codiant.com]to discuss the further projects and get a quote.
I can assist you with your requirement.
Please Connect with me:
Email – trish.ci@talentsfromindia.com
Skype - live:.cid.baff7c7dd9471b54
Thanks
Trish
If you are still on the lookout for some help I would be glad to help you out, as what you are wanting done is well within my area of expertise.
You can reach me on andrewjohnson56782@gmail.com
Cheers and Have a great day ahead,
Andrew
