Helm Chart Airgapped Deployment Guide
This guide covers deploying Rocket.Chat with MongoDB and Monitoring in an airgapped environment using Hauler to collect, package, and transfer all required artifacts.
LOW SIDE (Internet) HIGH SIDE (Airgapped)
1. Sync artifacts with Hauler 4. Load artifacts into Hauler store
2. Save to transportable archive 5. Copy to internal registry
3. Transfer via approved media --------> 6. Deploy with registry override
Prerequisites
Low Side (Internet-Connected):
- Hauler installed
helmCLI installed
High Side (Airgapped):
- Hauler installed
helmCLI installedkubectlconfigured for your cluster- Container registry accessible from Kubernetes cluster
Note: This guide was tested with Hauler v1.4.1
Part 1: Export Artifacts (Low Side)
Step 1: Create Hauler Manifest
Create a file named rocketchat-airgap-manifest.yaml:
apiVersion: content.hauler.cattle.io/v1
kind: Charts
metadata:
spec:
charts:
- name: rocketchat
repoURL: https://rocketchat.github.io/helm-charts
version: 6.32.1
add-images: true
add-dependencies: true
- name: monitoring
version: 0.0.14
add-images: true
- name: mongodb-kubernetes
repoURL: https://mongodb.github.io/helm-charts
version: 1.7.0
add-images: true
# Rocket.Chat runtime images - not needed if using the same version as the chart
# as the sync will automatically discover these images. Include explicitly if
# deploying a different version than what the chart specifies.
kind: Images
metadata:
annotations:
hauler.dev/platform: linux/amd64
spec:
images:
- name: registry.rocket.chat/rocketchat/rocket.chat:8.1.0
- name: docker.io/rocketchat/presence-service:8.1.0
- name: docker.io/rocketchat/ddp-streamer-service:8.1.0
- name: docker.io/rocketchat/account-service:8.1.0
- name: docker.io/rocketchat/authorization-service:8.1.0
- name: docker.io/library/nats:2.12-alpine
- name: docker.io/natsio/nats-box:0.19.2
- name: docker.io/natsio/nats-server-config-reloader:0.21.1
- name: docker.io/natsio/prometheus-nats-exporter:0.18.0
# MongoDB runtime images - these are deployed by the MongoDBCommunity CR,
# not the operator's Helm chart, so they must be listed explicitly.
kind: Images
metadata:
annotations:
spec:
images:
- name: quay.io/mongodb/mongodb-community-server:8.0.4-ubi8
- name: quay.io/mongodb/mongodb-agent:108.0.2.8729-1
Note: The
add-images: trueflag extracts all container images referenced in the Helm charts. The runtime image sections allow you to explicitly specify versions if deploying different versions than what the charts reference.
Step 2: Sync Artifacts
hauler store sync -f rocketchat-airgap-manifest.yaml
This downloads all Helm charts and container images to the local Hauler store.
Step 3: Verify Store Contents
hauler store info
Step 4: Save to Archive
hauler store save -f rocketchat-airgap.tar.zst
Part 2: Transfer to High Side
Transfer the following files to the airgapped environment using your organization’s approved transfer method:
| File | Size | Description |
rocketchat-airgap.tar.zst |
~5-8 GB | Compressed archive containing all charts and images |
hauler binary |
~50 MB | Hauler CLI (if not already installed on high side) |
Values files (.yaml) |
< 1 MB | Your customized Helm values files |
Included Artifacts
Helm Charts:
| Chart | Version |
| rocketchat | 6.32.1 |
| monitoring | 0.0.14 |
| mongodb-kubernetes | 1.7.0 |
| kube-prometheus-stack | 75.9.0 |
| grafana-operator | v5.18.0 |
| loki | 6.49.0 |
| mongodb (dependency) | 13.18.5 |
| postgresql (dependency) | 15.5.38 |
| nats (dependency) | 0.15.1 |
Container Images - Rocket.Chat & Dependencies:
| Image | Tag |
| registry.rocket.chat/rocketchat/rocket.chat | 8.1.0 |
| rocketchat/presence-service | 8.1.0 |
| rocketchat/ddp-streamer-service | 8.1.0 |
| rocketchat/account-service | 8.1.0 |
| rocketchat/authorization-service | 8.1.0 |
| library/nats | 2.12-alpine |
| natsio/nats-box | 0.19.2 |
| natsio/nats-server-config-reloader | 0.21.1 |
| natsio/prometheus-nats-exporter | 0.18.0 |
Container Images - MongoDB:
Container Images - Monitoring:
| Image | Tag |
| Quay | v0.83.0 |
| Quay | v3.4.2 |
| Quay | v0.28.1 |
| Quay | v1.9.1 |
| registry.k8s.io/kube-state-metrics/kube-state-metrics | v2.16.0 |
| Package grafana-operator · GitHub | v5.18.0 |
| grafana/grafana | 12.0.2 |
| grafana/loki | 3.6.3 |
| grafana/rollout-operator | v0.32.0 |
| kiwigrid/k8s-sidecar | 1.30.9 |
| otel/opentelemetry-collector-contrib | 0.143.0 |
| nginxinc/nginx-unprivileged | 1.29-alpine |
| Quay | RELEASE.2024-12-18T13-15-44Z |
| Quay | RELEASE.2024-11-21T17-21-54Z |
Part 3: Import Artifacts (High Side)
Step 1: Load Archive
hauler store load -f rocketchat-airgap.tar.zst
Step 2: Copy to Registry
hauler store copy --destination registry://<your-registry>:<port>
# Example:
hauler store copy --destination registry://registry.internal.local:5000
Part 4: Deploy Rocket.Chat
Step 1: Configure Registry Override
Create values files with your internal registry. Replace registry.internal.local:5000 with your registry address.
mongodb-operator-values.yaml:
global:
imageRegistry: registry.internal.local:5000
operator:
tolerations:
- key: "dedicated"
operator: "Equal"
value: "rocketchat"
effect: "NoSchedule"
nodeSelector:
dedicated: rocketchat
registry:
operator: registry.internal.local:5000/mongodb
database: registry.internal.local:5000/mongodb
initDatabase: registry.internal.local:5000/mongodb
agent: registry.internal.local:5000/mongodb
versionUpgradeHook: registry.internal.local:5000/mongodb
readinessProbe: registry.internal.local:5000/mongodb
monitoring-values.yaml:
global:
tolerations: &tolerations
- key: "dedicated"
operator: "Equal"
value: "rocketchat"
nodeSelector: &nodeSelector
opentelemetryCollector:
image:
registry: registry.internal.local:5000/otel/opentelemetry-collector-contrib
operator:
prometheusOperator:
image:
prometheusConfigReloader:
image:
tolerations: *tolerations
nodeSelector: *nodeSelector
prometheus:
prometheusSpec:
image:
kube-state-metrics:
image:
prometheus-node-exporter:
image:
grafana:
image:
repository: registry.internal.local:5000/grafana/grafana-operator
loki:
loki:
image:
gateway:
image:
singleBinary:
chunksCache:
enabled: false
resultsCache:
enabled: false
rocketchat-values.yaml:
global:
- key: "dedicated"
operator: "Equal"
value: "rocketchat"
image:
repository: rocketchat/rocket.chat
pullPolicy: IfNotPresent
microservices:
enabled: true
presence:
image:
repository: rocketchat/presence-service
ddpStreamer:
image:
repository: rocketchat/ddp-streamer-service
account:
image:
repository: rocketchat/account-service
authorization:
image:
repository: rocketchat/authorization-service
nats:
nats:
image: registry.internal.local:5000/library/nats:2.12-alpine
natsbox:
image: registry.internal.local:5000/natsio/nats-box:0.19.2
reloader:
image: registry.internal.local:5000/natsio/nats-server-config-reloader:0.21.1
exporter:
image: registry.internal.local:5000/natsio/prometheus-nats-exporter:0.18.0
mongodb:
enabled: false
host: <your-domain.com>
ingress:
enabled: true
ingressClassName: traefik
tls:
- secretName: rocketchat-tls
hosts:
- <your-domain.com>
extraEnv:
- name: OVERWRITE_SETTING_Show_Setup_Wizard
value: "completed"
- name: OVERWRITE_SETTING_Enterprise_License
value: |
<YOUR-LICENSE-KEY>
externalMongodbUrl: "mongodb://rocketchat:<password>@mongodb-0.mongodb-svc.rocketchat.svc.cluster.local:27017/rocketchat?authSource=rocketchat&replicaSet=mongodb"
Image Path Note: When using
global.imageRegistry, image repositories should NOT include the original registry prefix. The chart prependsglobal.imageRegistryautomatically:
global.imageRegistry: registry.internal.local:5000image.repository: rocketchat/rocket.chat- Result:
registry.internal.local:5000/rocketchat/rocket.chat
Custom CA Certificate (Optional)
If Rocket.Chat needs to trust a custom CA:
kubectl create configmap custom-ca-certs --from-file=ca-certificates.crt=path/to/your-ca.crt -n rocketchat
Then add to rocketchat-values.yaml:
extraEnv:
- name: NODE_EXTRA_CA_CERTS
value: /etc/ssl/certs/custom-ca/ca-certificates.crt
extraVolumes:
- name: custom-ca-certs
configMap:
extraVolumeMounts:
mountPath: /etc/ssl/certs/custom-ca
readOnly: true
Step 2: Install Helm Charts
helm install mongodb-kubernetes-operator oci://registry.internal.local:5000/mongodb/mongodb-kubernetes -n rocketchat -f mongodb-operator-values.yaml
helm install monitoring oci://registry.internal.local:5000/rocketchat/helm-monitoring -n rocketchat -f monitoring-values.yaml
helm install rocketchat oci://registry.internal.local:5000/rocketchat/helm-rocketchat -n rocketchat -f rocketchat-values.yaml
Step 3: Verify Deployment
kubectl get pods -n rocketchat
All pods should reach Running status and pull images from your internal registry.
Troubleshooting
Images Not Found
If pods fail to pull images:
- Verify the image exists in your registry
- Check for registry authentication issues with
kubectl get events -n rocketchat - Ensure
imagePullSecretsis configured if your registry requires authentication:imagePullSecrets: - name: registry-credentials
Double Registry Prefix Error
If you see errors like Failed to pull image "registry.internal.local:5000/registry.rocket.chat/rocketchat/rocket.chat":
The chart prepends global.imageRegistry to the repository path. Remove the registry prefix from image.repository:
# Wrong - causes double prefix
image:
repository: registry.rocket.chat/rocketchat/rocket.chat
# Correct
image:
Hauler Store Issues
If hauler store sync fails:
- Check network connectivity to registries
- Verify authentication for private registries:
hauler login <registry> -u <username> -p <password> - Check disk space - the store can grow large
