When I try to publish a new branch using git push --set-upstream origin testing. It checks the linting and it gets stuck.
- Version of Rocket.Chat Server: 6.5.0-develop
- Operating System: macOS 13.4.1 (22F82)
- Deployment Method:
- NodeJS Version: 14.21.3
- MongoDB Version: 6.0.3
- Proxy:
- Firewalls involved:
This is the log and it gets stuck at the end of the log
> api git:(testing) ✗ git push --set-upstream origin testing
> Update available v1.10.13 ≫ v1.10.14
> Run "npx @turbo/codemod update" to update
> • Packages in scope: @rocket.chat/account-service, @rocket.chat/account-utils, @rocket.chat/agenda, @rocket.chat/api-client, @rocket.chat/authorization-service, @rocket.chat/base64, @rocket.chat/cas-validate, @rocket.chat/core-services, @rocket.chat/core-typings, @rocket.chat/cron, @rocket.chat/ddp-client, @rocket.chat/ddp-streamer, @rocket.chat/eslint-config, @rocket.chat/favicon, @rocket.chat/fuselage-ui-kit, @rocket.chat/gazzodown, @rocket.chat/i18n, @rocket.chat/instance-status, @rocket.chat/livechat, @rocket.chat/log-format, @rocket.chat/logger, @rocket.chat/meteor, @rocket.chat/mock-providers, @rocket.chat/model-typings, @rocket.chat/models, @rocket.chat/omnichannel-services, @rocket.chat/omnichannel-transcript, @rocket.chat/password-policies, @rocket.chat/pdf-worker, @rocket.chat/poplib, @rocket.chat/presence, @rocket.chat/presence-service, @rocket.chat/queue-worker, @rocket.chat/random, @rocket.chat/release-action, @rocket.chat/rest-typings, @rocket.chat/server-fetch, @rocket.chat/sha256, @rocket.chat/stream-hub-service, @rocket.chat/tools, @rocket.chat/ui-client, @rocket.chat/ui-composer, @rocket.chat/ui-contexts, @rocket.chat/ui-theming, @rocket.chat/ui-video-conf, @rocket.chat/uikit-playground, @rocket.chat/web-ui-registration, rocketchat-services
> • Running lint in 48 packages
> • Remote caching disabled
> @rocket.chat/i18n:build: cache bypass, force executing aa2431d4aa119476
> @rocket.chat/account-utils:build: cache hit (outputs already on disk), replaying logs 7bc88913899c0e90
> @rocket.chat/cas-validate:build: cache hit (outputs already on disk), replaying logs 002aea04f4425242
> @rocket.chat/password-policies:build: cache hit (outputs already on disk), replaying logs d2e6ecfe51ad6b9f
> @rocket.chat/agenda:build: cache hit (outputs already on disk), replaying logs 7eda31f7837b9685
> @rocket.chat/logger:build: cache hit (outputs already on disk), replaying logs 3bfabd963e837e79
> @rocket.chat/tools:build: cache hit (outputs already on disk), replaying logs 368fc93a2884bd7d
> @rocket.chat/favicon:build: cache hit (outputs already on disk), replaying logs f14e5410eb3de1a1
> @rocket.chat/log-format:build: cache hit (outputs already on disk), replaying logs 1f6ba153b37c5e97
> @rocket.chat/server-fetch:build: cache hit (outputs already on disk), replaying logs 7b216f92996b8be7
> @rocket.chat/eslint-config:lint: cache hit (outputs already on disk), replaying logs 7f1cb75f66c4b447
> @rocket.chat/base64:build: cache hit (outputs already on disk), replaying logs 7324cef558492e12
> @rocket.chat/ui-composer:build: cache hit (outputs already on disk), replaying logs 133b5d718941ff78
> @rocket.chat/sha256:build: cache hit (outputs already on disk), replaying logs 554afa6e3c91a656
> @rocket.chat/core-typings:build: cache hit (outputs already on disk), replaying logs 53638e2fe68cccb1
> @rocket.chat/random:build: cache hit (outputs already on disk), replaying logs 4699254e1c8f179b
> @rocket.chat/account-utils:lint: cache hit (outputs already on disk), replaying logs dae4c6d62e4beaa0
> @rocket.chat/release-action:build: cache hit (outputs already on disk), replaying logs 594940e7bda41175
> @rocket.chat/cas-validate:lint: cache hit (outputs already on disk), replaying logs fc8e192df068adb0
> @rocket.chat/password-policies:lint: cache hit (outputs already on disk), replaying logs 524e513249d88689
> @rocket.chat/tools:lint: cache hit (outputs already on disk), replaying logs 6786d64c405432e5
> @rocket.chat/server-fetch:lint: cache hit (outputs already on disk), replaying logs d76c6db4835d9e51
> @rocket.chat/agenda:lint: cache hit (outputs already on disk), replaying logs c5fbba597f5b70ca
> @rocket.chat/logger:lint: cache hit (outputs already on disk), replaying logs 40c702bf425b2ff9
> @rocket.chat/ui-composer:lint: cache hit (outputs already on disk), replaying logs 97dcfa31bd4d5c56
> @rocket.chat/base64:lint: cache hit (outputs already on disk), replaying logs 5e4bb09457e40166
> @rocket.chat/favicon:lint: cache hit (outputs already on disk), replaying logs 449f5bdd28ef9011
> @rocket.chat/agenda:lint: /Users/macbookpro/Documents/cs527/Rocket.Chat/packages/agenda/src/Agenda.ts
> @rocket.chat/agenda:lint: 66:2 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: 69:2 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: 72:2 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: 125:4 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: 127:5 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: 605:3 warning Do not use "@ts-ignore" because it alters compilation errors @typescript-eslint/ban-ts-comment
> @rocket.chat/agenda:lint: ✖ 6 problems (0 errors, 6 warnings)
> @rocket.chat/log-format:lint: cache hit (outputs already on disk), replaying logs 878b2f96ad212b84
> @rocket.chat/sha256:lint: cache hit (outputs already on disk), replaying logs a8e301449169c4d9
> @rocket.chat/rest-typings:build: cache hit (outputs already on disk), replaying logs 83ccc040a420c513
> @rocket.chat/core-typings:lint: cache hit (outputs already on disk), replaying logs cefa3e768bb1367f
> @rocket.chat/model-typings:build: cache hit (outputs already on disk), replaying logs 3217d86734b6ee56
> @rocket.chat/random:lint: cache hit (outputs already on disk), replaying logs 85fb20053779b930
> @rocket.chat/pdf-worker:build: cache hit (outputs already on disk), replaying logs f1ea73c07c76d845
> @rocket.chat/ui-contexts:build: cache bypass, force executing e305c58e4dfdcf8d
> @rocket.chat/core-typings:lint: /Users/macbookpro/Documents/cs527/Rocket.Chat/packages/core-typings/src/Serialized.ts
> @rocket.chat/core-typings:lint: 5:14 warning Don't use `{}` as a type. `{}` actually means "any non-nullish value".
> @rocket.chat/core-typings:lint: - If you want a type meaning "any object", you probably want `object` instead.
> @rocket.chat/core-typings:lint: - If you want a type meaning "any value", you probably want `unknown` instead.
> @rocket.chat/core-typings:lint: - If you want a type meaning "empty object", you probably want `Record<string, never>` instead.
> @rocket.chat/core-typings:lint: - If you really want a type meaning "any non-nullish value", you probably want `NonNullable<unknown>` instead @typescript-eslint/ban-types
> @rocket.chat/core-typings:lint: ✖ 1 problem (0 errors, 1 warning)
> @rocket.chat/release-action:lint: cache hit (outputs already on disk), replaying logs e34a50c43cddf642
> @rocket.chat/model-typings:lint: cache hit (outputs already on disk), replaying logs 14337a928ba228aa
> @rocket.chat/api-client:build: cache hit (outputs already on disk), replaying logs a3ba4a88408eb0ff
> @rocket.chat/models:build: cache hit (outputs already on disk), replaying logs eeff7919eafa03ad
> @rocket.chat/pdf-worker:lint: cache hit (outputs already on disk), replaying logs e8351e3a4efd88d2
> @rocket.chat/rest-typings:lint: cache hit (outputs already on disk), replaying logs 9f6e3dae853dbcc5
> @rocket.chat/rest-typings:lint: /Users/macbookpro/Documents/cs527/Rocket.Chat/packages/rest-typings/src/v1/users/UsersGetAvatarSuggestionParamsGET.ts
> @rocket.chat/rest-typings:lint: 6:49 warning Don't use `{}` as a type. `{}` actually means "any non-nullish value".
> @rocket.chat/rest-typings:lint: - If you want a type meaning "any object", you probably want `object` instead.
> @rocket.chat/rest-typings:lint: - If you want a type meaning "any value", you probably want `unknown` instead.
> @rocket.chat/rest-typings:lint: - If you want a type meaning "empty object", you probably want `Record<string, never>` instead.
> @rocket.chat/rest-typings:lint: - If you really want a type meaning "any non-nullish value", you probably want `NonNullable<unknown>` instead @typescript-eslint/ban-types
> @rocket.chat/rest-typings:lint: ✖ 1 problem (0 errors, 1 warning)
> @rocket.chat/cron:build: cache hit (outputs already on disk), replaying logs 813f4cc4f3234801
> @rocket.chat/ddp-client:build: cache hit (outputs already on disk), replaying logs 56a29965e5e7fc26
> @rocket.chat/api-client:lint: cache hit (outputs already on disk), replaying logs ad6186e502bf7793
> @rocket.chat/models:lint: cache hit (outputs already on disk), replaying logs a9bb747fd05e2a76
> @rocket.chat/core-services:build: cache hit (outputs already on disk), replaying logs 3490a234ef1f44c0
> @rocket.chat/instance-status:build: cache hit (outputs already on disk), replaying logs cf7013640a511996
> @rocket.chat/ddp-client:lint: cache hit (outputs already on disk), replaying logs 6d527d46667846a5
> @rocket.chat/presence:build: cache hit (outputs already on disk), replaying logs 24930f1a3590ce0e
> @rocket.chat/stream-hub-service:build: cache hit (outputs already on disk), replaying logs 91029d5dbcf6f3ed
> @rocket.chat/core-services:lint: cache hit (outputs already on disk), replaying logs a4d72bebcd897059
> @rocket.chat/instance-status:lint: cache hit (outputs already on disk), replaying logs 2914357a0b5d60fd
> @rocket.chat/cron:lint: cache hit (outputs already on disk), replaying logs f651e0e0609727a2
> @rocket.chat/omnichannel-services:build: cache hit (outputs already on disk), replaying logs 6c2d0a3caed3ba9c
> @rocket.chat/authorization-service:build: cache hit (outputs already on disk), replaying logs 87e87722ceb422e5
> @rocket.chat/queue-worker:build: cache hit (outputs already on disk), replaying logs bfd4ef1784f8e217
> @rocket.chat/stream-hub-service:lint: cache hit (outputs already on disk), replaying logs db1a5e4fc2856bdb
> @rocket.chat/omnichannel-services:lint: cache hit (outputs already on disk), replaying logs 03ac74efe29c20d6
> @rocket.chat/presence-service:build: cache hit (outputs already on disk), replaying logs f7baf836d01d0744
> @rocket.chat/account-service:build: cache hit (outputs already on disk), replaying logs 75b900bb510f4256
> @rocket.chat/authorization-service:lint: cache hit (outputs already on disk), replaying logs d34e2ba97271bfad
> rocketchat-services:build: cache hit (outputs already on disk), replaying logs 8d79c7cac2b2f7cc
> @rocket.chat/presence:lint: cache hit (outputs already on disk), replaying logs e984c320ccb6a16d
> @rocket.chat/presence-service:lint: cache hit (outputs already on disk), replaying logs 8ddb059a2059bd2d
> @rocket.chat/queue-worker:lint: cache hit (outputs already on disk), replaying logs 9827b09c8c96bb4f
> @rocket.chat/account-service:lint: cache hit (outputs already on disk), replaying logs dee8f3911500c4ce
> @rocket.chat/i18n:lint: cache hit (outputs already on disk), replaying logs 95e80289a217fa13
> @rocket.chat/ui-contexts:lint: cache hit (outputs already on disk), replaying logs 5c333d0b6449d93b
> @rocket.chat/ui-theming:build: cache hit (outputs already on disk), replaying logs 57b3c452ba3ce9ea
> @rocket.chat/ui-video-conf:build: cache hit (outputs already on disk), replaying logs b46f2abfc812283d
> @rocket.chat/ddp-streamer:build: cache hit (outputs already on disk), replaying logs 952ec94be8871073
> @rocket.chat/mock-providers:build: cache hit (outputs already on disk), replaying logs db982bfb44439c26
> @rocket.chat/omnichannel-transcript:build: cache hit (outputs already on disk), replaying logs 0f09c782163f6590
> @rocket.chat/mock-providers:lint: cache hit (outputs already on disk), replaying logs 263992a0f228424d
> @rocket.chat/ui-client:build: cache hit (outputs already on disk), replaying logs f4f98709be2f0ae9
> @rocket.chat/omnichannel-transcript:lint: cache hit (outputs already on disk), replaying logs 44c206f91bd0923a
> @rocket.chat/ui-theming:lint: cache hit (outputs already on disk), replaying logs dea3a6e2ff5710cc
> @rocket.chat/ddp-streamer:lint: cache hit (outputs already on disk), replaying logs 028c1d5e8728f8ee
> @rocket.chat/gazzodown:build: cache hit (outputs already on disk), replaying logs a1aed93d65c497dc
> @rocket.chat/web-ui-registration:build: cache hit (outputs already on disk), replaying logs 3bbb622d4f6ce614
> @rocket.chat/ui-client:lint: cache hit (outputs already on disk), replaying logs 0a96e4bef190ec69
> @rocket.chat/livechat:build: cache hit (outputs already on disk), replaying logs 86d46a824fc6aa5c
> @rocket.chat/web-ui-registration:lint: cache hit (outputs already on disk), replaying logs 79ce0e0242840092
> @rocket.chat/fuselage-ui-kit:build: cache hit (outputs already on disk), replaying logs f103aadb64f7d273
> @rocket.chat/livechat:build: [BABEL] Note: The code generator has deoptimised the styling of /Users/macbookpro/Documents/cs527/Rocket.Chat/node_modules/katex/dist/katex.js as it exceeds the max of 500KB.
> @rocket.chat/livechat:build: Child
> @rocket.chat/livechat:build: WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
> @rocket.chat/livechat:build: This can impact web performance.
> @rocket.chat/livechat:build: Assets:
> @rocket.chat/livechat:build: 2.chunk.35aff.js (264 KiB)
> @rocket.chat/livechat:build: 6.chunk.db5f5.js (484 KiB)
> @rocket.chat/livechat:build: 7.chunk.98519.js (951 KiB)
> @rocket.chat/livechat:build: 8.chunk.e9bb9.js (665 KiB)
> @rocket.chat/livechat:build: 10.chunk.1aa1e.js (1.1 MiB)
> @rocket.chat/livechat:build: 11.chunk.7bd0f.js (650 KiB)
> @rocket.chat/gazzodown:lint: cache hit (outputs already on disk), replaying logs e0917feb5bd0368d
> @rocket.chat/fuselage-ui-kit:lint: cache hit (outputs already on disk), replaying logs bf056053585976b3
> @rocket.chat/uikit-playground:build: cache hit (outputs already on disk), replaying logs cb8fe182ec43ae03
> @rocket.chat/meteor:lint: cache miss, executing 7f35728ff33b1bfc
> @rocket.chat/uikit-playground:lint: cache hit (outputs already on disk), replaying logs 27c4a751c35f8ac6
> @rocket.chat/livechat:lint: cache hit, replaying logs ab14a4c8e94da308
> @rocket.chat/livechat:lint: /Users/macbookpro/Documents/cs527/Rocket.Chat/packages/livechat/src/components/Composer/index.tsx
> @rocket.chat/livechat:lint: 29:6 warning Prefer using an optional chain expression instead, as it's more concise and easier to read @typescript-eslint/prefer-optional-chain
> @rocket.chat/livechat:lint: 244:18 warning Forbidden non-null assertion @typescript-eslint/no-non-null-assertion
> @rocket.chat/livechat:lint: 252:22 warning Forbidden non-null assertion @typescript-eslint/no-non-null-assertion
> @rocket.chat/livechat:lint: ✖ 3 problems (0 errors, 3 warnings)
