Trying to configure Rocket Chat on AWS, following the guide, however I get this:
Requesting to rerun ./letsencrypt-auto with root privileges…
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
An unexpected error occurred:
Error creating new authz :: Policy forbids issuing for name
Please see the logfiles in /var/log/letsencrypt for more details
Are you using a standard .com .org .net (or any other common TLD) domain name or is it a .onion/.amazonaws.com domain?
Is the domain resolvable from the internet, as in, do you have public DNS set up that is pointing to the domain?
You said you are on AWS - So you’ll need to have an actual domain registered with public DNS pointing to the server. The .amazonaws.com domain that is registered to an AWS EC2 instance will not work as they are blacklisted as ‘high risk’ domains.
The reason for this is that they are ephemeral - You might have it today, but if you terminate that instance, someone else will have it tomorrow.
