Does 6.4.9 have a known memory leak issue?
Hi, I’ve noticed a slow steady increase in memory usage in my VM caused by the node process, and the VM is dedicated to running a Rocket.chat server. Is there a known memory leak issue in v6.4.9?
  • Version of Rocket.Chat Server: 6.4.9
  • Operating System: Redhat
  • Deployment Method: Docker
  • Number of Running Instances: 2
  • NodeJS Version: 14.21.3
  • MongoDB Version: 7.0.43
  • Proxy:
You are totally unsupported.
Upgrade now.
I am aware that 6.4.9 is totally unsupported. Unfortunately, upgrading is not a viable option at the moment. Is there a known memory leak issue that was fixed in later versions?
Ahhhh, lots of users or air gapped and don’t want to pay after they changed the limits?
Unsupported means exactly what it says.
No help whatsoever I’m afraid.
Even if there was an issue no one is going to look at it or fix it. You will just be told to upgrade and test on a supported version, no excuses. You had time to plan your upgrade.
As far as fixes go read the bugs & changelogs.
If you have a supported version and note an issue then open a bug.
Also be aware that your system contains multiple security vulnerabities. Check them on github.
Thank you for your advice. Please allow me to clarify the intent.
I am aware that there is a need to upgrade, unfortunately there are circumstancs beyond my control at the moment, and my intent in raising this topic is not for technical support (as I am aware of the EOL), but to write in a report that our Rocket.chat instance has a memory leak that affected its performance (if it does) and I need evidence to justify the claim.
That’s it.
Upgrade to a supported version.
There is no further advice.
