Desktop Program Startup not working
I have recently deployed Rocket.Chat here at our organization and are using the desktop (electron) app. When we installed the application we checked the box to lauch at computer startup.
We now have sporadic issues where the application is not starting up for some ends users. I assume this would be a registry option but was unable to find it.
Where is the startup options controlled as I current cannot find where this is managed.
  • Version of Rocket.Chat Server: 4.3.2
  • Deployment Method: Manual
  • NodeJS Version: 12.22.1
  • MongoDB Version: 4.4.11
  • Proxy: nginx
  • Firewalls involved: none
None.
the option ask doen’t exist :frowning: , but very often asking …
I found this entry in registry :frowning: Ordinateur\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\StartupFolder
You have to put RC link in the startup entry of windows shell, in C:\Users[USER]\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Thank you for the reply.
I have the .lnk in the startup folder (shell:startup) and it still does not launch. I was hoping there is some way, other than a reinstall, that I could force this to boot.
If not, I guess my end users will have to deal with it.
And with a portable application and the link in the startup shell ?
Is the application portable? I installed the electron application for Windows from rocket.chat/install.
The link is in the startup folder.
Sorry to “Necro” this thread. I fixed this with a bat file I put into the Startup folder that checks what version of installer you used (MSI vs EXE) and then runs the executable.
Put this file in the startup folder.
