This is a very annoying Issue that happened to me, after I have updated the app.
I do NOT recieve ANY notification SOUND from the rooms/channels.
I do get the notification Itself but without the sound.
It does work on DM’s like I hear the sound and everything but from my channels I don’t.
Hello, I’m facing the same issue and couldn’t be able to fix this. Have you found out any solution for this?
Thanks in advance!
After I tried some settings, I stumbled over the following: Click one the server name at the top-left and open “notification settings” and change from “mentions” (which should be standard) to “all” for the room / channel you would like to hear sounds whenever someone writes something
