/etc/nginx/conf.d
upstream rocket_backend {
server 127.0.0.1:3000;
server {
listen 443 ssl;
server_name example.domain.com;
access_log /var/log/nginx/rocketchat-access.log;
error_log /var/log/nginx/rocketchat-error.log;
ssl_certificate /etc/nginx/example.domain.com.crt;
ssl_certificate_key /etc/nginx/exampler.domain.com.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # don’t use SSLv3 ref: POODLE
location /admin {
allow 192.168.1.0/24;
deny all;
location / {
proxy_pass http://rocket_backend/;
proxy_http_version 1.1;
proxy_redirect off;
I can’t get the IP filter to work.
