I have deployed a rocketchat setup through official docker-compose and trying to expose the rocketchat with nginx in front. With the below configuration, I am getting the rocket chat page when I access rchost:3000 but when I access rocketchat through nginx, i.e rchost:80, I am getting only a dark grey screen and no error in browser console also.
The configurations are below,
Nginx config:
# Upstreams
upstream backend {
server localhost:3000;
# Redirect Options
server {
listen 80;
# server_name 172.16.1.22;
server_name rc.rage;
# enforce https
return 301 https://$server_name$request_uri;
# HTTPS Server
server {
listen 443;
#server_name 172.16.1.22;
ssl on;
ssl_certificate /etc/nginx/ssl/rocket-chat.crt;
ssl_certificate_key /etc/nginx/ssl/rocket-chat.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # don’t use SSLv3 ref: POODLE
location / {
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_redirect off;
Docker Compose:
version: '2'
services:
rocketchat:
restart: unless-stopped
volumes:
- ./uploads:/app/uploads
- PORT=3000
- ROOT_URL=http://localhost
- MAIL_URL=smtp://smtp.email
# - HTTP_PROXY=http://rc.rage
# - HTTPS_PROXY=http://rc.rage
- Accounts_UseDNSDomainCheck=flase
depends_on:
- mongo
ports:
- 3000:3000
labels:
- "traefik.backend:rocketchat"
- "traefik.frontend.rule:Host: your.domain.tld"
mongo:
image: mongo:3.2
volumes:
- ./data/db:/data/db
#- ./data/dump:/dump
labels:
- "traefik.enable:false"
mongo-init-replica:
image: mongo:3.2
command: 'mongo mongo/rocketchat --eval "rs.initiate({ _id: ''rs0'', members: [ { _id: 0, host: ''localhost:27017'' } ]})"'
depends_on:
- mongo
hubot:
image: rocketchat/hubot-rocketchat:latest
- ROCKETCHAT_URL=rocketchat:3000
- ROCKETCHAT_ROOM=GENERAL
- ROCKETCHAT_USER=bot
- ROCKETCHAT_PASSWORD=botpassword
- BOT_NAME=bot
- EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics
depends_on:
- rocketchat
labels:
volumes:
- ./scripts:/home/hubot/scripts
# this is used to expose the hubot port for notifications on the host on port 3001, e.g. for hubot-jenkins-notifier
ports:
- 3001:8080
