Hi guys, im working with Rocket Chat (web) and my custom OAuth.
It works great, but when i download the App ( Rocket Chat + ) and i try login in with some user from OAuth… it does not work. It even dont show the Custom OAuth button.
When i try login in it says “User has no password set” (and its okey… but should it be checking on OAuth if user exists ?)
Any idea ?
Best place for this type of thing is actually the Android repo where this missing feature actually has an issue open: https://github.com/RocketChat/Rocket.Chat.Android/issues/322
But yes basically Rocket.Chat+ does not have support for custom oauth yet, and unless you set a password, that error message is 100% correct. When logging in with oauth you’re authenticating with an oauth provider not Rocket.Chat.
Thanks @aaron.ogle
Im working on a temporal solution for this…
Im trying to implment AbstractOAuthFrament class
public class DgiOAuthFragment extends AbstractOAuthFragment {
@Override
protected String getOAuthServiceName() {
return "dgi";
@Override
protected String generateURL(LoginServiceConfiguration oauthConfig) {
return new HttpUrl.Builder().scheme("http")
.host("http://1.1.1.1:1111")
.addQueryParameter("client_id", "xyz123")
.addQueryParameter("display", "popup")
.addQueryParameter("scope", "email")
.addQueryParameter("state", getStateString())
.build()
.toString();
But my main issue is i dont know how to implement the:
- Token Path
- Identity Path
- Authorize Path
