I am trying to setup a custom oauth solution and I am getting a “No matching login attempt found”. The logs from the rocketchat container are: Meteor ➔ method public-settings/get → userId: undefined, arguments: [{}]
API ➔ debug Success {
statusCode: 200,
body: {
message: ‘{“msg”:“result”,“id”:“3”,“result”:{“update”:,“remove”:}}’,
success: true
API ➔ debug POST: /api/v1/method.callAnon/login
Exception while invoking method login Error: No matching login attempt found [145546287]
at MethodInvocation. (packages/accounts-oauth/oauth_server.js:35:21)
at packages/accounts-base/accounts_server.js:499:31
at tryLoginMethod (packages/accounts-base/accounts_server.js:1341:14)
at AccountsServer._runLoginHandlers (packages/accounts-base/accounts_server.js:497:22)
at AccountsServer.Accounts._runLoginHandlers (app/lib/server/lib/loginErrorMessageOverride.js:7:35)
at MethodInvocation.methods.login (packages/accounts-base/accounts_server.js:557:31)
at maybeAuditArgumentChecks (packages/ddp-server/livedata_server.js:1771:12)
at packages/ddp-server/livedata_server.js:1689:15
at Meteor.EnvironmentVariable.EVp.withValue (packages/meteor.js:1234:12)
at packages/ddp-server/livedata_server.js:1687:36
at new Promise ()
at Server.applyAsync (packages/ddp-server/livedata_server.js:1686:12)
at Server.apply (packages/ddp-server/livedata_server.js:1625:26)
at Server.call (packages/ddp-server/livedata_server.js:1607:17)
at Object.post (app/api/server/v1/misc.js:263:26)
at app/api/server/api.js:394:82
at Object._internalRouteActionHandler [as action] (app/api/server/api.js:394:39)
at Route.share.Route.Route._callEndpoint (packages/nimble_restivus/lib/route.coffee:150:32)
at packages/nimble_restivus/lib/route.coffee:59:33
at packages/simple_json-routes.js:98:9
=> awaited here:
at Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:60:12)
at Server.apply (packages/ddp-server/livedata_server.js:1638:22)
statusCode: 200,
body: {
message: ‘{“msg”:“result”,“id”:“4”,“error”:{“isClientSafe”:true,“error”:145546287,“reason”:“No matching login attempt found”,“message”:“No matching login attempt found [145546287]”,“errorType”:“Meteor.Error”}}’,
success: true
I am curious if there is an way of finding more information about the error so I can diagnose what is happening.
Server Hardware: Docker container
Version of Rocket.Chat Server: 3.15.0
Operating System: Docker container
Deployment Method: docker
DB Replicaset Oplog: mongodb://mongo:27017/local
NodeJS Version: 12.22.1 - x64
MongoDB Version: 4.0.24
Client Type: Browser Chrome 91.0.4472.77 (64-bit)
Setup new Rocketchat docker container enable custom oauth provider and try to login with confirmed good user name. After which the error that is given is “No matching login attempt found”. Is there a error log that I can check to find more information about what is going wrong.
After more testing with my oauth provider and increasing the log level in rocketchat I am getting this error.
{“line”:“69”,“file”:“oauth_server.js”,“message”:“Unable to base64 decode state from OAuth query: undefined”,“time”:{"$date":1624039466464},“level”:“warn”}
{“line”:“69”,“file”:“oauth_server.js”,“message”:“Unable to base64 decode state from OAuth query: undefined”,“time”:{"$date":1624039466465},“level”:“warn”}
server.js:204 API ➔ debug POST: /api/v1/method.callAnon/login
Failed login detected - Username[unknown] ClientAddress[10.255.0.2] ForwardedFor[10.255.0.2] XRealIp[undefined] UserAgent[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.106 Safari/537.36]
at new Promise ()
=> awaited here:
server.js:204 API ➔ debug Success {
statusCode: 200,
body: {
message: ‘{“msg”:“result”,“id”:“14”,“error”:{“isClientSafe”:true,“error”:145546287,“reason”:“No matching login attempt found”,“message”:“No matching login attempt found [145546287]”,“errorType”:“Meteor.Error”}}’,
success: true
Is the oauth provider supposed to return the state value to rocktechat with the authorization code or am I misunderstanding this error log?
So additional information I have gotten from the logs in rocketchat has to do with the OAuth handshake.
Error: Failed to complete OAuth handshake with edxoauth at https://edx.centos-vm/oauth/token. getaddrinfo ENOTFOUND edx.centos-vm
at CustomOAuth.getAccessToken (app/custom-oauth/server/custom_oauth_server.js:148:18)
at Object.handleOauthRequest (app/custom-oauth/server/custom_oauth_server.js:205:26)
at OAuth._requestHandlers. (packages/oauth2/oauth2_server.js:10:33)
at middleware (packages/oauth/oauth_server.js:170:5)
at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40
=> awaited here:
This issue seems to be related to my setup being containers on the same domain and rocketchat not being able to resolve the oauth2 container is there a setting within rocketchat that I am missing to get rocketchat to resolve other containers with the swarm.
I am not using sticky sessions but I am using apache to direct all of my traffic. I only have one rocketchat container running I have not set up any more than that. The oauth server is a container that is running on the same network and the same machine as the rocktechat container. I am able to ping the apache container from the rocketchat container and vis versa via the container names.
That is how I was testing the ping from inside of the rocketchat container to the apache container and it works fine and I also tested ping from inside the apache container to the rocktechat container and it works just fine as well
