Hello. I use Ubuntu 18.04.
When I install Rocket.Chat with Docker and a manual installation I get the following error (only Docker with snaps works):
Does anyone know why?
Note: The installation is successful because the database fills with 56 collections. The process doesn’t stop, it keeps running.
cat << EOF |sudo tee -a /lib/systemd/system/rocketchat.service
[Unit]
After=network.target remote-fs.target nss-lookup.target nginx.service mongod.service
[Service]
ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=rocketchat
User=rocketchat
Environment=MONGO_URL=mongodb://localhost:27017/rocketchat?replicaSet=rs01 MONGO_OPLOG_URL=mongodb://localhost:27017/local?replicaSet=rs01 ROOT_URL=http://localhost:3000/ PORT=3000
[Install]
WantedBy=multi-user.target
EOF
In Environment it had localhost instead of 0.0.0.0 and it did not recognize the folders.
I hope that it would be useful to someone.
Thanks for sharing the solution
