Hi, I want to integrate rocket chat real time api on Flutter app for communication between users. Can anyone tell me about sequence of API I need to consume for this. I need it in real time.
Probably need to start here:
My objective is to communicate between two users using Rocket chat real time api.
First of all, I consumed âcreateDirectMessageâ that gives me rId. And then I send message using âsendMessageâ api. But message is not received at receiver end.
I double checked that userName provided sent on âcreateDirectMessageâ is correct.
I think you are going to have to give us a lot more information here.
How is your server setup. What version?
Some samples of code?
final String webSocketUrl = âwss://open.rocket.chat/websocketâ;
I am using this socket url.
Flow of events:
- Login using this api
{âmsgâ:âmethodâ,âmethodâ:âloginâ,âparamsâ:[{âuserâ:{âemailâ:âxxxâ},âpasswordâ:{âdigestâ:âxxxxâ,âalgorithmâ:âsha-256â}}],âidâ:â47â}
this api responds with:
{âmsgâ:âresultâ,âidâ:â47â,âresultâ:{âidâ:âxxxxâ,âtokenâ:âxxxxxâ,âtokenExpiresâ:{"$date":1631366708063},âtypeâ:âpasswordâ}}
- Then I use this Api
{âmsgâ:âsubâ,ânameâ:âstream-room-messagesâ,âparamsâ:[âroom-idâ,false],âidâ:âstream-room-messages-65RVqEc_16_MxJWZXbF1pw==â}
that gives this reponse
{âmsgâ:ânosubâ,âidâ:âstream-room-messagesâs3KM9yYvRlMZuhAfooT6w==â}
- then I call this api to send message
{âmsgâ:âmethodâ,âmethodâ:âsendMessageâ,âparamsâ:[{"_id":âuser-idâ,âridâ:âroom-id,â,âmsgâ:âHello Hassan!â}],âidâ:â48â}
That responds me with
{âmsgâ:âresultâ,âidâ:â48â}
But message I sent from client 1 is not received on client 2 stream.
I have mentioned url I am using on a message before
Can you format your code when you paste it? It makes it much easier to read!
I copied a bit of yours to https://beautifier.io/ to test
âmsgâ: âmethodâ,
âmethodâ: âsendMessageâ,
âparamsâ: [{
"_id": âuser-idâ,
âridâ: âroom-id,â, <<< extra comma here after room-id?
âmsgâ: âHello Hassan!â
âidâ: â48â
It should look like this from the docs?
"msg": "method",
"method": "sendMessage",
"id": "42",
"params": [
"_id": "message-id",
"rid": "room-id",
"msg": "Hello World!"
Yours seems to be missing:
Please go back and check all your code carefully, and use our examples to test.
Which stream do I need to listen to receive messages on my client mobile application? Message sent from my client application is received by rocket chat web client, but vice versa is not functioning. Thanks in advance.
Before working on rocket chat, I created a simple meteor server. And on that server,
meteor.collections['messages']
listening to the above stream was working
Working on a simple meteor server is probably not like working on a full Rocket.Chat server.
Iâll have to try and find you some more help as this is not a simple exercise and you are not helping by not giving decent information.
I really suggest you read some of the links in here on âHow to ask for helpâ
These two are particularly useful.
Rocket.Chat Version: 3.16.0-develop
NodeJS Version: 12.22.1 - x64
MongoDB Version: 4.2.8
MongoDB Engine: wiredTiger
Platform: darwin
Hardware: Macbook Pro 2017
OS: MacOS BigSur
Client: Flutter App
My objective is to establish communication between Flutter clients.
I am using API in this sequence currently.
"msg": "method",
"method": "login",
"params": [
"resume": "tIz9zGw9kyPjpD-Hz2pjXsxw3jpOrnzSyeiGBvD7qwY"
"id": "1"
Above is the first API I am using.
Then, create room I am using below api
"msg": "method",
"method": "createDirectMessage",
"params": [
"hassan123"
"id": "3"
and then
"msg": "method",
"params": [
"_id": "R4aglvDhjgx0Tv0SIBXkH40g",
"rid": "LQPcW3fdd66A6w6baTPc9F3G5czz9T45AQ",
"msg": "Hello"
"id": "4"
Message is received on rocket chat web client. But Its not getting received on Flutter client.
StreamBuilder(
stream: BlocProvider.of(context)
.meteor
.collections[âmessagesâ],
Itâs the stream that worked on simple meteor client. But its not working with rocket chat
Hii hassan ,have you implemented rocket chat in your flutter app,
i also want use Rocket chat in flutter app,if you have done ,could you help me
