Hello all!
We using snap version rocket, and after I change track from 2.x to 3.x I have some problems.
We make integration Jira and rocket by web hook (with script on rocket side).
Rocket version now 3.12.1
Jira 8.5.1
Project avatar and user avatar does not shows, but in Browser version all shows right
and issue avatar show larger than it is be
The script what we are using:
Script
/*jshint esnext:true*/
const DESC_MAX_LENGTH = 300;
const JIRA_LOGO = 'data:image/png;base64,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';
function stripDesc(str) {
if (str === null || typeof str == 'undefined') {
return "";
return (str && str.length > DESC_MAX_LENGTH) ? str.slice(0, DESC_MAX_LENGTH - 3) + '...' : str;
function prepareAttachment({issue, user}, text) {
let issueType = issue.fields.issuetype;
const currentTime = (new Date()).toISOString();
let res = {
author_name: user.displayName,
author_icon: user.avatarUrls['32x32'],
thumb_url: issueType.iconUrl,
ts: currentTime
if (text) {
text = text.replace(/\{\{(user|issue)\.([^a-z_0-9]+)\}\}/g, (m, type, key) => (type==='user' ? user : issue)[key]);
res.text = text;
return res;
class Script {
process_incoming_request({request}) {
const data = request.content;
try {
if (!data.issue || (data.user && data.user.name === 'gitlab')) {
return;
let issue = data.issue;
let baseJiraUrl = issue.self.replace(/\/rest\/.*$/, '');
let user = data.user;
let assignedTo = (issue.fields.assignee && issue.fields.assignee.name !== user.name) ? `, assigned to ${issue.fields.assignee.displayName}` : '';
let issueSummary = `[${issue.key}](${baseJiraUrl}/browse/${issue.key}) #${issue.fields.summary}# _(${issue.fields.priority.name.replace(/^\s*\d*\.\s*/, '')}${assignedTo})_`;
let message = {
icon_url: (issue.fields.project && issue.fields.project.avatarUrls && issue.fields.project.avatarUrls['48x48']) || JIRA_LOGO
, attachments: []
if (data.webhookEvent === 'jira:issue_created') {
message.attachments.push(prepareAttachment(data, `*Created* ${issueSummary}:\n${stripDesc(issue.fields.description)}`));
} else if (data.webhookEvent === 'jira:issue_deleted') {
message.attachments.push(prepareAttachment(data, `*Deleted* ${issueSummary}`));
} else if (data.webhookEvent === 'jira:issue_updated') {
if (data.changelog && data.changelog.items) { // field update
let logs = [];
data.changelog.items.forEach((change) => {
if (!change.field.match('status|resolution|comment|priority') ) {
return;
if (change.field==='description') {
logs.push(`Changed *description* to:\n${stripDesc(change.toString)}`);
} else {
logs.push(`*${change.field}* changed from ${change.fromString} to *${change.toString}*`);
logs.length && message.attachments.push(prepareAttachment(data, `*Updated* ${issueSummary}:\n - ${logs.join('\n - ')}`));
if (data.comment) { // comment update
let comment = data.comment;
let action = comment.created !== comment.updated ? 'Изменили комментарий' : 'Прокомментировали';
message.attachments.push(prepareAttachment(data, `*${action}* on ${issueSummary}:\n${stripDesc(comment.body)}`));
if (message.text || message.attachments.length) {
return {content:message};
} catch(e) {
console.log('jiraevent error', e);
return {
error: {
success: false,
message: `${e.message || e} ${JSON.stringify(data)}`
