Building Rocket chat for mobile apps
Hi there
As per the captioned title, it is mentioned in here in this url https://rocket.chat/docs/developer-guides/mobile-apps/ that we can build our own version that can be restricted to connect to your own server only and have your own branding.
However i noticed that the link at https://github.com/RocketChat/Rocket.Chat.Cordova/releases/ is already been deprecated.
Can you pls help me with the new github repo where i can follow the similar instruction to build own version of mobile app and the steps required to do the needful.
Thanking you in advance!
I’m afraid if you can’t even find the correct repo I doubt you are going to be able to build anything yourself…
Note React is probably the way forward.
Thanks for the info.
hello, gulamgaus.
Did you solve this problem? I’m in the same situation. I need help.
