Bug with port 300
  • Version of Rocket.Chat Server: 1.1.1
  • Deployment Method: manual
  • NodeJS Version: v8.11.4
  • MongoDB Version: 4.0.5
  • Proxy: nginx
  • Firewalls involved: No
Helllo!
We have bugs with port 3000
In settings General, in filed Site URL added https://chat.domain.com/.
But this field changing in http://chat.domain.com:3000
Please tell me what happened.
Where is bugs.
screenshot_22
Hi Denis,
I don’t really know what’s the problem with this. It just says the Site URL you entered on installation wizard is different than the URL you’re using currently.
By simply clicking yes it will update it and all will be fine. Not a bug, this is working exactly as intended to help you out with a configuration issue.
But it happens every day.
Are you restarting every day? If so you’ll need to see the faq for the snap. Use the command to set the root url.
sudo snap set rocketchat-server siteurl=yoursiteurl
No, sometimes when the desktop application is restarted, or in the browser.
I will try this command, thanks!
