I have a problem when I use an admin user, an error opens directly in the middle of the page with the following information: Application Error
The GUI application just crashed.
I’ve done some research but I can’t find the solution, how can I solve it?
Version of Rocket.Chat Server: 6.12.1
Operating System: Ubuntu 20
Deployment Method: SNAP
Number of Running Instances:
DB Replicaset Oplog:
NodeJS Version:
MongoDB Version:
Proxy:
Firewalls involved:
reetp
September 17, 2024, 8:28am
2
Nothing like these existing issues?
opened 07:40AM - 12 Sep 24 UTC
closed 07:14PM - 21 Oct 24 UTC
type: bug
Tasked
### Description:
When admin dismisses banner with notification, that new versio… n 6.12 is available, the app crashes:
When I remove manually in mongo the role "admin" from user, everything works. Admins, that dont dismiss this notification are not affected.
Tried to delete some items from `rocketchat_banner_dismiss`, but it didnt help.
Notifications are working correctly even when the app is crashed, mobile app also works (but not the admin panel in mobile app)
### Server Setup Information:
- Version of Rocket.Chat Server: 6.12.0
- Number of Users: about 70
- Operating System: linux
- Deployment Method: docker
- DB Replicaset Oplog: enabled
- NodeJS Version: 14.21.3 - x64
- MongoDB Version: 4.4.29
### Additional context
Same problem described here: https://forums.rocket.chat/t/application-error-the-application-gui-just-crashed/20534
### Relevant logs:
browser console:
console.js:288 Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=object%20with%20keys%20%7B%7D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
at aX (_define_property.mjs:14:1)
Version of Rocket.Chat Server: 6.11.1
Operating System: Ubuntu 20.04.6
Deployment Method: snap
NodeJS Version: 14.21.2
MongoDB Version: 5.0.15
Proxy: nginx
Firewalls involved: No
the page error only show to Admin users. the normal users can use site mormaly.
We stopped and backup the env, and restore the backup to new fresh version 6.12.0 and it show same issue.
the browse…
And currently no solution but it is being looked at by the team.
I’ve already tried to make these corrections, but without success, and I saw that even https://open.rocket.chat has a problem, maybe it’s an error from the last update.
reetp
September 18, 2024, 11:33am
4
What do your logs tell you ?
Things to check:
Use a clean browser with empty cache/cookies
Make sure the server root url is set to your https host ( I hope you are running a reverse proxy and https?)
Make sure that is the same URL as registered in your cloud workspace. Login and check.
hi , the same error. cant enter admin panel. The GUI application just crashed. Tested clean browser , tested on mobile app all the same. my version 6.12.1. snap. debian
reetp
September 23, 2024, 12:59pm
7
logs dont say anything about error. plese tell me where to dig.
reetp
September 24, 2024, 1:20pm
9
See the above bug, and this comment and link.
stat: waiting response
Tasked
### Description:
### Relevant logs:
browser console:
dosent work, i use snap and tried this command
sudo rocketchat-server.mongo --eval ‘db.rocketchat_banner.updateMany({active: true },{ $set: { active: false }})’ parties
it says rocketchat-server.mongo command not found.
reetp
September 25, 2024, 6:51am
11
Clearly you have something wrong but I’m on vacation right now and can’t do much.
