I am sending an audio message to the chat
As a result, I get the displayed chat time equal to 00:00
Neither I, non-users can listen to this message
The file exists on the server in the file folder.
I also decided to try doing it directly, without the FortiGate (fortiweb) proxy at xxx.xxx.xxx.xxx: 3000, and I didn’t have a button to send an audio message in my chat.
Well you can try a quick test on 3.15 but I think most likely the issue will be in your Fortigate box - as I suspected at the outset. You need to take a careful look at the reverse proxy (and a look at the logs too!)
i did a clean install 3.15.0
and get the same problem.
I am not using a router for the latest tests.
Showing my config file
/etc/nginx/sites-enabled/default
server {
listen 80 default_server;
listen [::]:80 default_server;
# SSL configuration
# listen 443 ssl default_server;
# listen [::]:443 ssl default_server;
# Note: You should disable gzip for SSL traffic.
# See: https://bugs.debian.org/773332
# Read up on ssl_ciphers to ensure a secure configuration.
# See: https://bugs.debian.org/765782
# Self signed certs generated by the ssl-cert package
# Don't use them in a production server!
# include snippets/snakeoil.conf;
root /var/www/html;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name _;
location / {
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
# pass PHP scripts to FastCGI server
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
upstream backend {
server 127.0.0.1:3000;
#HTTPS Server
server {
listen 443;
server_name chat.xxxxxxx.biz;
# You can increase the limit if your need to.
client_max_body_size 200M;
ssl on;
ssl_certificate /etc/nginx/certificate;
ssl_certificate_key /etc/nginx/certificate;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # don’t use SSLv3 ref: POODLE
location / {
proxy_pass http://backend;
proxy_http_version 1.1;
proxy_redirect off;
