vmsman
April 26, 2022, 1:35am
#1
RocketChat 4.6.3, Mongo 5.0.7 / wiredTiger (oplog Enabled). Database Migration 258 (April 25, 2022 8:14 PM).
Chats are working fine. File uploads stuck at 0% from all clients. Tried switching to filesystem and same and tried switching back to fridfs and same.
I also tried reindexing the uploads with no effect:
docker exec -it mongodb mongo
use rocketchat
db.rocketchat_uploads.chunks.createIndex( { files_id: 1, n: 1 }, { unique: true } )
Have you seen this other thread?
Greetings!
When i restore a database from another server using the restoredb tool in a new server, all data have been migrated, but the files uploads are too slow, stucking in 0% for 2…3… minutes before finish the transfer. This new server has a normal behavior before the database restore in the fresh install.
The problem occurs in the 2.x stable / 3.x stable and 4.x stable
Logs didn´t show anything anormal…
URL site is correct.
Any ideas?
Thanks a lot.
Server Setup Informat…
vmsman
April 26, 2022, 9:20pm
#3
I did see that message. So, I have discussion threads running normally except for picture/image uploads. I don’t know what a manual database restore is which is what the linked article refers to. I did a database backup a few days ago when I converted from mmap to wiredTiger as prescribed. Do you know what commands I can use to fix this?
