REPOST: No reply previously
I’m running Rocket Chat version 1.0.3 via Snap on a Raspberry Pi 4.
Following the instructions here it states in Prerequisites:
the fastest and largest capacity microSD you can get, we recommend 128GB Class 10 or higher
However, when i run Mongo installed within Snap is states:
NOTE: This is a 32 bit MongoDB binary.
32 bit builds are limited to less than 2GB of data
Can i understand why so much disk capacity is needed if this is the DB constraint?
