Hi all,
We currently have 3 instances of RC running on three different virtual machines on-premises. All installed the same way (snap, nginx). Recently I deployed an on-premises instance of Jitsi Meet Conferencing Server in it’s own VM and configured one of three RC server to use it with token authentication. Works fine.
Now my question is: may I configure the other two RC instances to use the same Jitsi server, or do I need to create a separate instance of Jitsi for each instance on RC?
If I may do it, should I use the same app_id\secret for all RC instances, or there is a way to use different ones for each RC instance?
VM resources and network bandwidth are not a problem. We have enough power in our virtualization infrastructure to feed Jitsi server.
Regards,
Compaq
- Version of Rocket.Chat Server: 7.0.0
- Operating System: Ubuntu 24.04.1 LTS (GNU/Linux 6.8.0-52-generic x86_64)
- Deployment Method: snap
- Number of Running Instances: 1 on each virtual machines. Currently there are 3 VMs.
- DB Replicaset Oplog:
- NodeJS Version:
- MongoDB Version:
- Proxy: nginx
- Firewalls involved: yes
