I installed Rocket.Chat on Ubuntu 20.04 server.
Followed the official guide: Rocket.Chat in Ubuntu - Rocket.Chat Docs
I have a problem with running. Something bad with mongod.
systemctl status mongod.service
● mongod.service - MongoDB Database Server
Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2021-02-09 20:42:17 UTC; 3min 12s ago
Docs: https://docs.mongodb.org/manual
Process: 15141 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=exited, status=100)
Main PID: 15141 (code=exited, status=100)
Feb 09 20:42:16 teamspeak systemd[1]: Started MongoDB Database Server.
Feb 09 20:42:17 teamspeak systemd[1]: mongod.service: Main process exited, code=exited, status=100/n/a
Feb 09 20:42:17 teamspeak systemd[1]: mongod.service: Failed with result ‘exit-code’.
- Version of Rocket.Chat Server: latest
- Operating System: Ubuntu 20.04 server
- Deployment Method: tar
- DB Replicaset Oplog:
- NodeJS Version: 12.18.4
- MongoDB Version: 4.0.22
- Proxy: apache
- Firewalls involved: fw inactive
If I run mongo --eval ‘db.runCommand({ connectionStatus: 1 })’
MongoDB shell version v4.0.22
connecting to: mongodb://127.0.0.1:27017/?gssapiServiceName=mongodb
2021-02-09T20:49:25.116+0000 E QUERY [js] Error: couldn’t connect to server 127.0.0.1:27017, connection attempt failed: SocketException: Error connecting to 127.0.0.1:27017 :: caused by :: Connection refused :
connect@src/mongo/shell/mongo.js:356:17
@(connect):2:6
exception: connect failed
thank you
