I am noticing repeated occurrences of mongo generating ~2k entries in syslog, often after a period of seeing nothing for hours. This also seems to coincide with a period of server instability which may or may not be related.
I’ve added the top 100 entries in today’s log below with the description truncated to show only the command. The total number of entries was 2702 between 00:00:03 and 01:18:1.
I have one user accessing the server via web and one user via REST API, though not at the time the logs were generated
- Version of Rocket.Chat Server: 3.8.3
- Operating System: Ubuntu 20.04
- Deployment Method: Snap
- NodeJS Version: 12.18.4
- MongoDB Version: 3.6.14
- Proxy: nginx
- Firewalls involved: Simple port based firewall
All logged by rocketchat-server.rocketchat-mongo
| COMMAND | [conn316] command parties.users command |
| COMMAND | [conn298] command parties.rocketchat_notification_queue command |
| COMMAND | [ftdc] serverStatus was very slow |
| COMMAND | [conn297] command admin.$cmd command |
| WRITE | [conn277] update parties.rocketchat_settings command |
| COMMAND | [conn277] command parties.$cmd command |
| WRITE | [conn298] update parties.instances command |
| COMMAND | [conn298] command parties.$cmd command |
| COMMAND | [conn285] command parties.users command |
| COMMAND | [conn298] command parties.users command |
| COMMAND | [conn277] command parties.users command |
| WRITE | [conn288] update parties.users command |
| COMMAND | [conn288] command parties.$cmd command |
| COMMAND | [conn218] command parties.users command |
| COMMAND | [conn288] command parties.users command |
| WRITE | [conn285] update parties.instances command |
| COMMAND | [conn285] command parties.$cmd command |
| COMMAND | [conn317] command parties.meteor_accounts_loginServiceConfiguration command |
| COMMAND | [conn316] command parties.rocketchat_livechat_inquiry command |
| COMMAND | [conn319] command parties.rocketchat_integrations command |
| COMMAND | [conn324] command parties.rocketchat_integration_history command |
| COMMAND | [conn329] command parties.rocketchat_roles command |
| COMMAND | [conn320] command parties.rocketchat_livechat_department_agents command |
| COMMAND | [conn323] command parties.rocketchat_subscription command |
| COMMAND | [conn325] command parties.usersSessions command |
| COMMAND | [conn321] command parties.rocketchat_message command |
| COMMAND | [conn328] command parties.rocketchat_room command |
| COMMAND | [conn314] command parties.rocketchat_permissions command |
| COMMAND | [conn315] command parties.rocketchat_settings command |
| COMMAND | [conn318] command admin.$cmd command |
| COMMAND | [conn327] command parties.instances command |
| COMMAND | [conn322] command parties.users command |
| COMMAND | [conn325] command parties.meteor_accounts_loginServiceConfiguration command |
| COMMAND | [conn321] command parties.rocketchat_subscription command |
| COMMAND | [conn316] command parties.rocketchat_room command |
| COMMAND | [conn320] command parties.rocketchat_message command |
| COMMAND | [conn323] command parties.rocketchat_roles command |
| COMMAND | [conn317] command parties.rocketchat_livechat_department_agents command |
| COMMAND | [conn314] command parties.rocketchat_livechat_inquiry command |
| COMMAND | [conn319] command parties.usersSessions command |
| COMMAND | [conn329] command parties.rocketchat_integration_history command |
| COMMAND | [conn328] command parties.rocketchat_integrations command |
| COMMAND | [conn326] command parties.rocketchat_permissions command |
| COMMAND | [conn327] command parties.users command |
| COMMAND | [conn324] command parties.rocketchat_settings command |
| COMMAND | [conn298] command admin.$cmd command |
| COMMAND | [conn315] command parties.instances command |
| COMMAND | [conn328] command parties.rocketchat_livechat_inquiry command |
| COMMAND | [conn325] command parties.rocketchat_integration_history command |
| COMMAND | [conn322] command parties.meteor_accounts_loginServiceConfiguration command |
| COMMAND | [conn314] command parties.rocketchat_room command |
| COMMAND | [conn326] command parties.rocketchat_message command |
| COMMAND | [conn323] command parties.rocketchat_livechat_department_agents command |
| COMMAND | [conn321] command parties.usersSessions command |
| COMMAND | [conn317] command parties.rocketchat_subscription command |
| COMMAND | [conn316] command parties.rocketchat_permissions command |
| COMMAND | [conn324] command parties.users command |
| COMMAND | [conn320] command parties.instances command |
| COMMAND | [conn277] command admin.$cmd command |
| COMMAND | [conn328] command parties.rocketchat_livechat_department_agents command |
| COMMAND | [conn329] command parties.meteor_accounts_loginServiceConfiguration command |
| COMMAND | [conn327] command parties.rocketchat_integration_history command |
| COMMAND | [conn317] command parties.rocketchat_message command |
| COMMAND | [conn326] command parties.rocketchat_integrations command |
| COMMAND | [conn288] command parties.rocketchat_notification_queue command |
| COMMAND | [conn322] command parties.rocketchat_settings command |
| COMMAND | [conn315] command parties.users command |
| COMMAND | [conn324] command parties.instances command |
| COMMAND | [conn327] command parties.rocketchat_livechat_inquiry command |
| COMMAND | [conn326] command parties.users command |
| COMMAND | [conn314] command parties.rocketchat_subscription command |
| COMMAND | [conn320] command parties.rocketchat_roles command |
| COMMAND | [conn317] command parties.usersSessions command |
| COMMAND | [conn323] command parties.meteor_accounts_loginServiceConfiguration command |
| WRITE | [conn218] update parties.instances command |
| COMMAND | [conn325] command parties.rocketchat_livechat_department_agents command |
| COMMAND | [conn218] command parties.$cmd command |
| COMMAND | [conn322] command parties.instances command |
