I have trialled Rocket.Chat Cloud and it appears to be worth installing on my own server however I am struggling to get it to work.
I have a Virtual Private Server (VPS) with full root access.
The server is running CentOS Linux 7.8.2003 (Core), with my control panel software being Plesk Obsidian v18.0.29_build1800200825.21.
The instructions for installing the Docker image appear to require a number of manual steps at the SSH prompt which im not sure I feel comfortable with as I don’t really understand what the steps will do to my production server.
I do have a domain ready for use, mindmatters.chat, which is already secured with an SSL Cert.
Can I install Rocket.Chat natively using the Docker interface within Plesk?
My experience with Docker is very limited.
I’m guessing I need to install the Mongo Docker Image ( I presume the standard “official” image is okay? ). Presuming that this is correct, is the latest version okay to use?
I presume I then also need to install the Rocket Chat Docker Image, but which one?
Docker Hub or Docker Hub
Once both are installed I presume I then need to map the volumes for each image to local paths.
How do I then get Rocket.Chat to talk to the Mongo Image? Does Mongo require any configuring? I only have experience with MySQL, so have no idea if I need to create any users accounts in Mongo DB?
Any support and help would really be appreciated!
Thank you
