we use rocket.chat since years on a local installation. For our installation we use a rocket-chat.company.local Domain.
It looks like, that with version 7.0.0 .local domains aren’t accepted anymore
Fehler: cannot perform the following tasks:
- Den Konfigurationshook von Snap "rocketchat-server" ausführen (run hook "configure": [ERROR] "https://rocket-chat.company.local/" is not a valid url)
Does this have a reason? Is there a way to get this running again? Maybe we can change the url directly somewhere in a configuration file? Under the client-settings it is no problem to define the url to the https://rocket-chat.company.local/ But than there is a mismatch between the snap-configuration (snap get rocketchat-server siteurl) and the GUI.
It runs under the community licence with ~100 users.
The server has a permanent connection to the internet - so airgapped shouldn’t be an issue.
But the user clients only running local to the reverse proxy (apache, on the same host). The proxy has a local certificate (certified by our company CA) to allow “approved” https-connections.
Is there a way to define the siteurl without using the snap set rocketchat-server siteurl=https://rocket-chat.company.local? Or wouldn’t this change something, because the verification is done elsewhere?
