Role AND group mapping with custom oauth using keycloak
I am trying to set up group and role mapping from keycloak to rocketchat. Role mapping works fine, but when i want to add group mapping as well, nothing happens. Is it even possible? Because there is only one field for group/role mapping in the customoauth settings. Thanks for your help.
  • Version of Rocket.Chat Server: 3.8.8
  • Operating System: Debian stretch
  • Deployment Method: docker on k8s
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
We can create the user in keycloak and that user can log in with rocket chat.
My question is can we make this user as admin for rocketchat using keycloak??
here is the documentation for that Keycloak - Rocket.Chat Docs
But only works until RC 3.18.3, the feature was removed in >4.x.
Thanks @d3h, I have followed this Blog but no use… Here I have given the details
adding the required roles to client
Details of Role
Adding the mappers for the client
Mappers details
Add that role to user
Please help with this
There is no need to make a composite role. Just create the role for the client. Create the mapper and give the role to the user.
And you need to set the role mapper in Rc-Administration-Menu > Oauth too.
Thank you @d3h . I need one small clarification.
Did you say the below items ??
Sorry for the german screenshot, but it’s the one above the Roles/Groups field for channel mapping
Thank you so much @d3h, I will try this
Hi, @d3h I have tried this. But I can’t make the keycloak created user as an admin of rocket chat.
I have both keyclaok and the rocketchat was in docker.
Here there is no rocket chat administrative access.
Did you relog? You can check your access token in keycloak under client scope > evaluate. Then there must be something like
roles { admin }
Ok @d3h I will check
