I have put rocketchat behind envoyproxy. The problem that I am facing is that the rocketchat keeps showing the “Connecting…” bar periodically And each time rocketchat sends the following requests:
Following is the envoyproxy config that I am using. I would really appreciate it if anyone could help me. thnx in advance.
envoy.yaml:
static_resources:
listeners:
- name: listener_0
address:
socket_address:
address: 0.0.0.0
port_value: 443
filter_chains:
- filters:
- name: envoy.filters.network.http_connection_manager
typed_config:
'@type': type.googleapis.com/envoy.extensions.filters.network.http_connection_manager.v3.HttpConnectionManager
stat_prefix: ingress_http
access_log:
- name: envoy.access_loggers.stdout
typed_config:
"@type": type.googleapis.com/envoy.extensions.access_loggers.stream.v3.StdoutAccessLog
upgrade_configs:
upgrade_type: websocket
route_config:
virtual_hosts:
- name: local_service
domains:
typed_per_filter_config:
envoy.filters.http.ext_authz:
"@type": type.googleapis.com/envoy.extensions.filters.http.ext_authz.v3.ExtAuthzPerRoute
check_settings:
context_extensions:
virtual_host: local_service
routes:
#====rocketchat route config====
- match:
prefix: '/'
route:
cluster: service_rocketchat
disabled: true
http_filters:
- name: envoy.filters.http.ext_authz
typed_config:
'@type': type.googleapis.com/envoy.extensions.filters.http.ext_authz.v3.ExtAuthz
http_service:
path_prefix: /api/auth/verify-token
server_uri:
uri: 'node-auth-server:80'
cluster: service_auth_server_cluster
timeout: 0.25s
authorization_response:
allowed_upstream_headers:
patterns:
- prefix: 'x-ag-'
authorization_request:
allowed_headers:
patterns:
- exact: 'cookie'
- name: envoy.filters.http.compressor
typed_config:
"@type": type.googleapis.com/envoy.extensions.filters.http.compressor.v3.Compressor
response_direction_config:
common_config:
min_content_length: 100
content_type:
- text/html
- application/json
- application/javascript
disable_on_etag_header: true
request_direction_config:
common_config:
enabled:
default_value: false
runtime_key: request_compressor_enabled
compressor_library:
typed_config:
"@type": type.googleapis.com/envoy.extensions.compression.gzip.compressor.v3.Gzip
memory_level: 3
window_bits: 10
compression_level: best_compression
compression_strategy: default_strategy
- name: envoy.filters.http.router
clusters:
- name: service_rocketchat
connect_timeout: 30s
type: LOGICAL_DNS
dns_lookup_family: V4_ONLY
load_assignment:
cluster_name: service_rocketchat
endpoints:
- lb_endpoints:
- endpoint:
address:
socket_address:
address: rocketchat
port_value: 3002
