I have successfully installed Rocket.Chat on Raspbian Buster from snap.
Installed corebot to get the Lets Encrypt certificates and installed nginx to create the reverse proxy.
The whole setup is perfectly working, users logging in, but Android users. They can’t log in, the server address refuses to connect. Found out on this forum it is due to a websocket. Others like web browsers or iPhones all work as expected
But I cant figure out how to configure the nginx to keep the websocket working for Android clients.
Please, whoever made this work, be so kind and provide a working confidence file example. Thanks
- Version of Rocket.Chat Server: 1.0.3
- Operating System: Raspbian Buster 4.19.97-v7l+
- Deployment Method: snap
- NodeJS Version: v8.11.4
- MongoDB Version: 3.2.15
- Proxy: nginx
- Firewalls involved: no, directly exposed to a internet fixed ip address
This is my configuration of nginx:
/etc/nginx/sites-enable/@default
Upstreams
upstream backend {
server 127.0.0.1:3000;
HTTPS Server
server {
listen 443;
server_name chat.ourdomain.mobi;
# You can increase the limit if your need to.
client_max_body_size 200M;
ssl on;
ssl_certificate /etc/nginx/certificate.crt;
ssl_certificate_key /etc/nginx/certificate.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # don’t use SSLv3 ref: POODLE
location / {
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_redirect off;
the etc/nginx/nginx.conf is standard:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/.conf;
include /etc/nginx/sites-enabled/*;
the error log does not show any errors
