Noob question - Begin customizations but using existing Monbo db
HI. We’ve been using the standard community version for a few years (and have a healthy Mongo db full of posts). I would like to setup a DEV environment using the latest Git repo source code but populate that DEV env with a copy of my production db. Basicly, how do I build the system from the source code, then deploy that code to use my copy of the production db?
  • Operating System: Ubuntu 18.04.3
  • Deployment Method: Tar
  • NodeJS Version: 12.21.1
  • MongoDB Version: 4.0.24
  • Proxy: Apache
If you are doing this on a separate box first setup Mongo and import your DB, then run your dev system connecting to the new test DB.
Just have plenty of backups everywhere!!
Thanks John. It is on a brand new box.
My question is really around “replacing” the standard build with a new build. I’m not super familiar with NPM and Meteor yet, so the various steps for building are still foreign to me right now. Here are the steps I’ve used to simply install RC for the past couple of years: Rocket.Chat in Ubuntu - Rocket.Chat Docs. Here is what I’ve played with in cloing the repo and doing a build for it:https://developer.rocket.chat/guides/developer/quick-start-on-linux
If I use the repo clone/build steps, that seems to use .meteor/local/db for the path to the mongo db, and I’ve not been successful in getting that build up and running with the copy of my production db. Those build steps do a “meteor npm start”, which runs its own Mongo server (based on what I see in a ps -ef display). I’d love to get that “repo build” simply moved and running like I do with the “manual build steps” in the first doc above, which starts mongod and rocketchat as services.
Scott
Ha - a good point I can now see. Doh.
I need to go find the brains department and get you some help!! Might be quiet as it is the weekend so could be Monday.
At least for now get the thing running and you can test on a fresh DB - I think your hands are going to be full finding your way around Meteor I believe!!
Thank you John! Will look forward to some thoughts early this coming week.
Scott
I can share my prod to dev copy method, but we are using docker deployment.
  1. Do mongodb backup whithout these collections
  • rocketchat_message_read_receipt,
  • rocketchat_message,
  • rocketchat_statistics,
  • rocketchat_uploads,
  • rocketchat_sessions,
  • rocketchat_apps_log,
  • rocketchat_integration_history,
  • rocketchat__trash,
  • rocketchat_oembed_cache
  1. Move that backup file to dev host server
  2. On that dev host server stop running docker containers docker stop $(docker ps -q)
  3. Delete current data
rm -rf /var/lib/docker/volumes/rocketchat_rocket_mongo_data_1/_data/ *
rm -rf /var/lib/docker/volumes/rocketchat_rocket_mongo_data_2/_data/ *
rm -rf /var/lib/docker/volumes/rocketchat_rocket_mongo_data_3/_data/ *
  1. unpack backup tar xvf rc_mongo_dev_$DATE.tar -C /var/lib/docker/volumes/rocketchat_rocket_mongo_dump/_data
  2. Start containers (3 for example) docker start rocketchat_s-rc-srv-01_1 rocketchat_s-rc-srv-02_1 rocketchat_s-rc-srv-03_1
  3. Configure Replica Set and most important change PROD url to DEV
docker exec rocketchat_s-rc-srv-01_1 /usr/bin/mongo --ssl --sslAllowInvalidCertificates -- eval "rs.initiate({ _id: 'rs0', members: [ { _id: 0, host: 's-rc-srv-01:27017' } ]})"
docker exec rocketchat_s-rc-srv-01_1 mongorestore --ssl --sslAllowInvalidCertificates
docker exec rocketchat_s-rc-srv-01_1 /usr/bin/mongo --ssl --sslAllowInvalidCertificates -- eval 'db.rocketchat_settings.update({"value":"https://rc-prod.company.com"},{$set:{"value":"https://rc-dev.company.com"}})' rocketchat
docker exec rocketchat_s-rc-srv-01_1 /usr/bin/mongo --ssl --sslAllowInvalidCertificates -- eval 'rs.add( { host: "s-rc-srv-02:27017" } )'
docker exec rocketchat_s-rc-srv-01_1 /usr/bin/mongo --ssl --sslAllowInvalidCertificates -- eval 'rs.add( { host: "s-rc-srv-03:27017" } )'
  1. Finaly start RC docker containers docker start rocketchat_rocketchat_1_1 rocketchat_rocketchat_2_1 rocketchat_rocketchat_3_1
I hope my method can help you to accomplish your goal
Hi, Anton. Thanks for your detailed process!
My setup is a regular Ubuntu and Apache setup where Mongo and RC run as services. Part of what I’m trying to figure out is how to “build” the RC application code from a Git clone (then modified) so I can simply run it in in the same Ubuntu/Apache setup where Mongo and RC are run as services. I can successfully dump and restore a Mongo db in that kind of setup. For building the app itself, the instructions and shell script examples in the Git repo show samples of runing the app in several setups, but not the one I describe.
Scott
OK - I understand you need to do something akin to this:
mongorestore --db meteor folder_with_mongo_dump/
Can you have a play and let us know? I’d like to document it of possible.
Hi, guys. Sorry I went dark for a while…travel and life got in the way.
So, I’ve made some good headway on this. I have managed to get a “build” of the RC source code with a copy of my production data in the mongo db.
My build steps come from the example script incluced with the repo (remember this is in an Ubuntu/Apache config with no Docker or snap):
meteor --allow-superuser npm install
npm audit fix
meteor --allow-superuser build --server-only --directory /storage/RC/rocket.chat
npm audit fix
cd /storage/RC/rocket.chat/bundle/programs/server
npm install
npm audit fix
meteor --allow-superuser npm install --save @nivo/core
npm audit fix
chown -R rocketchat:rocketchat /storage/RC
My next question is exactly what meteor does when it “builds”. For example, if I pull a new copy of the repo and execute these commands, all is well. If I then simply run the script again (i.e., rebuild the app again), it dies when running the “meteor --allow-superuser build --server-only” command with this output (is there a folder I need to wipe out before “rebuilding”?):
/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/meteor-promise/promise_server.js:218
throw error;
SyntaxError: Unexpected token u in JSON at position 1
at JSON.parse ()
at /home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/tools/fs/optimistic.ts:321:17
at wrap.makeCacheKey (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/tools/fs/optimistic.ts:36:15)
at recomputeNewValue (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/optimism/src/entry.ts:182:31)
at Slot.withValue (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/@wry/context/lib/context.js:73:29)
at reallyRecompute (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/optimism/src/entry.ts:165:19)
at Entry.recompute (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/optimism/src/entry.ts:85:9)
at optimistic (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/optimism/src/index.ts:101:25)
at /home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/tools/fs/optimistic.ts:366:19
at find (/tools/isobuild/package-source.js:1339:30)
at /tools/isobuild/package-source.js:1395:27
at Array.forEach ()
at find (/tools/isobuild/package-source.js:1374:22)
at Array.forEach ()
at find (/tools/isobuild/package-source.js:1406:25)
at Array.forEach ()
at Array.forEach ()
at Array.forEach ()
at Array.forEach ()
at /tools/isobuild/package-source.js:1418:34
at Object.withCache (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/tools/fs/files.ts:1663:18)
at PackageSource.findSources (/tools/isobuild/package-source.js:1418:18)
at SourceArch.getFiles (/tools/isobuild/package-source.js:960:32)
at /tools/isobuild/compiler.js:406:23
at /tools/isobuild/compiler.js:186:28
at /tools/isobuild/compiler.js:185:11
at Function.
.each._.forEach (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/underscore/underscore.js:186:9)
at Object.compile (/tools/isobuild/compiler.js:180:5)
at /tools/isobuild/bundler.js:3268:24
at Object.capture (/tools/utils/buildmessage.js:283:5)
at bundle (/tools/isobuild/bundler.js:3214:31)
at /tools/isobuild/bundler.js:3157:32
at Object.withCache (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/fs/tools/fs/files.ts:1663:39)
at Object.bundle (/tools/isobuild/bundler.js:3157:16)
at buildCommand (/tools/cli/commands.js:1082:30)
at /tools/cli/commands.js:945:25
at Function.run (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/tools/tool-env/tools/tool-env/profile.ts:289:14)
at /tools/cli/commands.js:943:18
at /home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/meteor-promise/fiber_pool.js:43:40
=> awaited here:
at Promise.await (/home/ubuntu/.meteor/packages/meteor-tool/.2.1.1.ixi3z9.hw65m++os.linux.x86_64+web.browser+web.browser.legacy+web.cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/meteor-promise/promise_server.js:60:12)
at /tools/cli/main.js:1529:7
Welcome back!
This is something I don’t know, but someone who may will be about some time soon.
<Note to self - must do this!!>
