I have a problem related to mongodb. When accessing the rocket via browser, the error appeared: 502 Bad Gateway. So I followed the logs to find a problem when the rocket tries to start mongodb.
With the command “sudo service snap.rocketchat-server.rocketchat-server status” I notice that rocket-mongo does not start the service:
root@ip-172-30-0-43:/var/snap/rocketchat-server/common# sudo service snap.rocketchat-server.rocketchat-server status
● snap.rocketchat-server.rocketchat-server.service - Service for snap application rocketchat-server.rocketchat-server
Active: active (running) since Tue 2020-05-12 21:05:53 -03; 1min 23s ago
Main PID: 7446 (startRocketChat)
Tasks: 2
Memory: 408.0K
CPU: 77ms
CGroup: /system.slice/snap.rocketchat-server.rocketchat-server.service
├─7446 /bin/bash /snap/rocketchat-server/1436/bin/startRocketChat
└─7488 sleep 30
May 12 21:05:53 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-server.service: Service hold-off time over, scheduling restart.
May 12 21:05:53 ip-172-30-0-43 systemd[1]: Stopped Service for snap application rocketchat-server.rocketchat-server.
May 12 21:05:53 ip-172-30-0-43 systemd[1]: Started Service for snap application rocketchat-server.rocketchat-server.
May 12 21:05:53 ip-172-30-0-43 rocketchat-server.rocketchat-server[7446]: Mongo is not available, can’t start. Waiting 10 seconds and trying again
May 12 21:06:03 ip-172-30-0-43 rocketchat-server.rocketchat-server[7446]: Mongo is not available, can’t start. Waiting 15 seconds and trying again
May 12 21:06:18 ip-172-30-0-43 rocketchat-server.rocketchat-server[7446]: Mongo is not available, can’t start. Waiting 20 seconds and trying again
May 12 21:06:38 ip-172-30-0-43 rocketchat-server.rocketchat-server[7446]: Mongo is not available, can’t start. Waiting 25 seconds and trying again
May 12 21:07:03 ip-172-30-0-43 rocketchat-server.rocketchat-server[7446]: Mongo is not available, can’t start. Waiting 30 seconds and trying again
With the command “sudo systemctl status snap.rocketchat-server.rocketchat-mongo.service” I verified that the service has a failure to start:
● snap.rocketchat-server.rocketchat-mongo.service - Service for snap application rocketchat-server.rocketchat-mongo
Active: failed (Result: start-limit-hit) since Tue 2020-05-12 20:24:33 -03; 46min ago
Process: 6096 ExecStart=/usr/bin/snap run rocketchat-server.rocketchat-mongo (code=exited, status=100)
Main PID: 6096 (code=exited, status=100)
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Main process exited, code=exited, status=100/n/a
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Unit entered failed state.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Failed with result ‘exit-code’.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Service hold-off time over, scheduling restart.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: Stopped Service for snap application rocketchat-server.rocketchat-mongo.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Start request repeated too quickly.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: Failed to start Service for snap application rocketchat-server.rocketchat-mongo.
May 12 20:24:33 ip-172-30-0-43 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Failed with result ‘start-limit-hit’.
Then I used the command “sudo journalctl -u snap.rocketchat-server.rocketchat-mongo” to get more information about the problem:
I CONTROL [initandlisten] MongoDB starting : pid=6118 port=27017 dbpath=/var/snap/rocketchat-server/common 64-bit host=ip-1
I CONTROL [initandlisten] db version v3.4.20
I CONTROL [initandlisten] git version: 447847d93d6e0a21b018d5df45528e815c7c13d8
I CONTROL [initandlisten] allocator: tcmalloc
I CONTROL [initandlisten] modules: none
I CONTROL [initandlisten] build environment:
I CONTROL [initandlisten] distarch: x86_64
I CONTROL [initandlisten] target_arch: x86_64
I CONTROL [initandlisten] options: { net: { bindIp: “127.0.0.1” }, processManagement: { pidFilePath: "/var/snap/rocketchat-
I - [initandlisten] Detected data files in /var/snap/rocketchat-server/common created by the ‘wiredTiger’ storage eng
I STORAGE [initandlisten]
I STORAGE [initandlisten] ** WARNING: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine
I STORAGE [initandlisten] ** See http://dochub.mongodb.org/core/prodnotes-filesystem
I STORAGE [initandlisten] wiredtiger_open config: create,cache_size=487M,session_max=20000,eviction=(threads_min=4,threads_
E STORAGE [initandlisten] WiredTiger error (-31803) [1589325873:8409][6118:0x7f93934abd00], txn-recover: Recovery failed: W
I - [initandlisten] Assertion: 28595:-31803: WT_NOTFOUND: item not found src/mongo/db/storage/wiredtiger/wiredtiger_k
I STORAGE [initandlisten] exception in initAndListen: 28595 -31803: WT_NOTFOUND: item not found, terminating
I NETWORK [initandlisten] shutdown: going to close listening sockets…
I NETWORK [initandlisten] removing socket file: /tmp/mongodb-27017.sock
I NETWORK [initandlisten] shutdown: going to flush diaglog…
I CONTROL [initandlisten] now exiting
I CONTROL [initandlisten] shutting down with code:100
The error found in the log is this:
STORAGE [initandlisten] WiredTiger error (-31803) [1589325873:8409][6118:0x7f93934abd00], txn-recover: Recovery failed: WT_NOTFOUND: item not found
Did you go through this problem?
I appreciate any help that comes up.
Version of Rocket.Chat Server:
Name Version Rev Tracking Publisher Notes
core 16-2.44.3 9066 latest/stable canonical✓ core
rocketchat-server 2.4.12 1436 latest/stable rocketchat✓ - -
Operating System:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION=“Ubuntu 16.04.2 LTS”
NAME=“Ubuntu”
VERSION=“16.04.2 LTS (Xenial Xerus)” -
Deployment Method:
Number of Running Instances:
01 -
DB Replicaset Oplog:
NodeJS Version:
MongoDB Version:
db version v3.0.15
git version: b8ff507269c382bc100fc52f75f48d54cd42ec3b -
Proxy:
Firewalls involved:
The error started without changing the server, the first error message was observed when accessing the rocket through the browser: 502 Bad Gateway
