[HOW TO] Upgrading 4.2.x to Latest (4.3.1) - Ubuntu (Manual mode)
Backup your complete installation before proceeding! You’ve been WARNED! :slight_smile:
1. Stop MongoDB and Rocket.Chat service
sudo systemctl stop mongod
sudo systemctl stop rocketchat
2. Rename your current Rocket.Chat Folder (for backup purposes in case upgrade fails)
sudo mv /opt/Rocket.Chat /opt/Rocket.Chat_bk
From here you can follow the normal Ubuntu installation.
3. Download the latest Rocket.Chat release.
curl -L https://releases.rocket.chat/latest/download -o /tmp/rocket.chat.tgz
tar -xzf /tmp/rocket.chat.tgz -C /tmp
4. Install
cd /tmp/bundle/programs/server && npm install
5. Move new installation to /opt folder.
sudo mv /tmp/bundle /opt/Rocket.Chat
No need to add rocketchat user and group since this has been already established.
6. Change owner of the Rocket.Chat folder back to rocketchat.
sudo chown -R rocketchat:rocketchat /opt/Rocket.Chat
7. Restart MongoDB and Rocket.Chat Services
sudo systemctl start mongod
sudo systemctl start rocketchat
Done! If everything is functioning as intended, you can delete your old Rocket.Chat backup folder.
Thank you for this guide. I have not been successful in moving our installation to either Docker or Snap, so this guide is very helpful when staying on manual installation.
I assume the process is the same for Debian?
Edit: Just ran the the commands, and it worked fine. I do get an npm audit note, stating that ‘underscore’ should be updated. Is it safe to do so?
According to Rocket.Chat installation debian manual, step 4 would be:
(cd /tmp/bundle/programs/server; npm i)
I wouldn’t know what the ‘underscore’ is referencing. You can try it. If it breaks, redo and leave it in.
