Fresh installation via snap returns exception
After fresh installing on Ubuntu 14.04 LTS I’m getting:
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: Exception in added observe/observeChanges callback: TypeError: Cannot read property 'split' of null
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at packages/rocketchat:lib/server/lib/validateEmailDomain.js:13:37
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at RocketChat.settings.callbacks.(anonymous function).forEach.callback (packages/rocketchat:lib/lib/settings.js:69:61)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Array.forEach (<anonymous>)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at forEach.item (packages/rocketchat:lib/lib/settings.js:69:41)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Object.load (packages/rocketchat:lib/lib/settings.js:67:14)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Object.added (packages/rocketchat:lib/server/functions/settings.js:261:31)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at _CachingChangeObserver.added (packages/minimongo/local_collection.js:1305:28)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at added (packages/minimongo/local_collection.js:707:29)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at runWithEnvironment (packages/meteor.js:1240:24)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at packages/meteor.js:1253:14
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at packages/mongo/observe_multiplex.js:182:30
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Function._.each._.forEach (packages/underscore.js:139:11)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Object.task (packages/mongo/observe_multiplex.js:176:9)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at Meteor._SynchronousQueue.SQp._run (packages/meteor.js:869:16)
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: at packages/meteor.js:846:12
lut 02 10:31:21 server rocketchat-server.rocketchat-server[27891]: Updating process.env.MAIL_URL
Any advice please?
The important question here of course is… Does it go on? If you restart the computer or the snap does it work? Let us know a bit more of what you tried so far
Yes It’s working. I did nothing and it just started. Dont know why
napisał:
If it comes back or persists please open an issue so we can track that exception down.
