Files uploaded to AmazonS3/MinIO get expiresAt and disappear despite URL expiry & retention disabled
I’m running Rocket.Chat version 8.0.1 in a Docker container and minIO also in a docker container for file uploads.
Files uploaded via Rocket.Chat (store: AmazonS3:Uploads) are automatically assigned an expiresAt timestamp and become unavailable after ~1 day, even though:
  • URL expiration is set to 0
  • File retention policies are disabled
Environment:
  • Rocket.Chat version: x.y.z
  • Deployment: Docker
  • Storage: AmazonS3 (MinIO backend)
  • MongoDB: 7.0
Observed Behavior:
  • Uploaded files work immediately.
  • After ~1 day, files stop being downloadable/previewable.
  • In MongoDB, rocketchat_uploads documents always have expiresAt = uploadedAt + ~1 day.
  • expiresAt persists for new uploads even after disabling URL expiry & retention policies.
What I’ve Checked / Tried:
  • FileUpload_S3_URLExpiryTimeSpan = 0 in admin settings
  • Disabled all retention policies
  • Verified Mongo indexes; expiresAt index is not TTL
  • Only one Rocket.Chat + Mongo instance running
Questions:
  1. Should Rocket.Chat continue setting expiresAt when URL expiry and retention are disabled?
  2. How can uploads remain accessible indefinitely with AmazonS3/MinIO?
  3. Are there server-side jobs or TTL configs outside Mongo that delete files based on expiresAt?
  4. If this is a bug, which part of the code controls setting expiresAt for S3 uploads?
This issue is fixed!
rooms.media uploads the files as unconfirmed by default. You need to confirm them by sending a message that references it with mediaConfirm endpoint.
By default, unconfirmed files are removed after 1 day. Confirmed files are not removed automatically (except with retention policy enabled)
